After looking at a number of different options I decided to buy this monitor with a view to returning it if it wasn't good enough. It arrived today and initially I was ready to send it back without opening the box because I was expecting the newer /01 model with 2 hdmi ports and according to the label on the box it was the older /00 model. When I opened the box to my surprise it had two hdmi ports so either Philips have updated the original model or stuck the wrong label on the monitor I bought. Date of manufacture was Sep 2019.
I had the original Philips 40in 4k model and the 43 looks a lot bigger at least height wise, probably due to the stand being taller. I think this is due to the connection ports being at the bottom rather than the side. Speaking of which it was a real pain attaching cables to the ports - had to lie the monitor on its back and even then struggled to fit the cables in.
Initial impressions are very good. Very bright and sharp screen - I've turned the brightness down to 30 and even then it's still quite bright. Text looks very sharp, colours are very rich. There is some screen uniformity issues at the sides where it's slightly darker but only noticeable on a white background and even then you have to turn your head to see it. Viewing angles are fine from where I'm sitting almost 3ft away from it. I tried it on both Linux - my main OS - and Windows 10 and both look good. I think it looks better in a darker room as you'd expect from a VA panel. Darker backgrounds also look better - mainly because it's so bright! The OCUK forums look really nice and sharp on it. I also tried Android Studio which looks great in Darcula (the default Dark mode).
PS4 Pro looks excellent the HDR is very good. Tried out God of War, Uncharted Lost Legacy and Darksiders 3 - all look great. Also tried Dark Souls 2 on the PC (Linux Steam via Proton) which looked really good - much brighter and deeper colours than my old Philips. The sound also is great through the speakers and very loud playing games.
It comes with a handy remote which is pretty lag free to use as long as you point it at the bottom right of the screen.
So overall I'm very happy with it - I may have gotten lucky with the panel but maybe Philips sorted out most of the initial reported issues and it's now worth a punt on. I think it's a pretty good product for the price with some minor issues but so far I haven't seen any major problems which would make me want to return it. Fingers crossed it stays that way!
