- 10 May 2004
- Middlesex
Really not sure why you have the plates under your toes, never heard of this before, its normally plates under heals to simulate lifting shoes, but you already have those.
Your feet are to close together in my opinion for a low bar squat, you want to widen your stance by maybe 2" per side.
Definitely better then before though.
I was going with the below:
- stick some 1.25/2.5kg plates under your toes and stand a 25kg plate up where your butt would hit
I guess it's to stop me from moving my weight to my toes.
I will try widening my stance more. I think flexibility may be an issue if I go wider but I will give it a go.
I just realised, I forgot to put the plate under my butt. Whoops!
