- 28 Sep 2014
- Scotland
I will say that the radeon 7's hbm2 ram makes games loading times non existent compared to the nvidia gddr6, its like the difference between ssd and hdd.
And the drivers are much nicer with the AMD but if they crash the pc needs restarting, as with the nvidia if it crashes it just recovers itself.
I hate to say this but although i loved my radeon 7 so much, this card is just better in nearly every way..........
100% false.
Games textures is stored on hard disk either SSD and HDD. When you launched games and it allocated some RAM need to launched games to reached the game menu and then when you started to played game, it will display loading screen. Behind the loading screen you never see what it was doing, the game actually in fact was busy loaded the level or map textures data from hard disk to RAM and then RAM loaded all textures data to GPU VRAM. When the textures loaded to VRAM is completed and the GPU is started to rendered the scenes as game started to play.
Shadow of the Tomb Raider benchmark loading time.
Radeon VII loading time started at 0:11 and end at 0:38 when benchmark started to run. HBM2 took 27 seconds.
RTX 2080 loading time started at 0:15 and end at 0:29 when benchmark started to run. GDDR6 took 14 seconds.
So HBM2 did not makes games loading times non existent compared to GDDR6 but HBM2 is slower than GDDR6.
You made big mistake bought Radeon VII. Terrible decision.
Not really surprised to heard that Radeon driver crashed will need PC restarted. Horrible driver. Not impressed.
