OcUK Staff
Any news on restock?
Requested an ETA on our order. Will post here if I have any info back!
Tough one - the AW34 is pretty much compatible with all modern games. The 49 though seems to be only Racing / MMO / Battlefield / New Triple AA games like latest COD.
It would depend on what games you play. If you like PUBG do not go with the 49
A 34” ultrawide is just as tall as the 49”. Worst case if the game doesn’t play nice with then 49” then it’s basically playing as a 34” screen.
Yup true! I got my 34 inch alienware in.. I think its big enough. I need some desk space for other stuff haha.
I am still in two minds but gsync is gorgeous.. not sure if freesync is the same. also i think my 2080 might just burn when trying to power a CRG9.
im havign to my head to one end of the screen just with this.
im also a bit concerned about huds going to the corner in 32:9.
Some of the games that natively support 32 9 actually put the hud stuff towards the middle of the screen
So my 1070 will struggle to power this beast?
unfortunately yesSo my 1070 will struggle to power this beast?
Thanks a lot for the reply.On some FreeSync models interpolation (scaling) on the monitor is not supported with FreeSync active. You should be able to use GPU scaling instead as covered in this article - https://www.amd.com/en/support/kb/faq/gpu-68. So you'd need to set 'Scaling Mode' to 'Maintain aspect ratio' (or whatever they call it in the new AMD Radeon Settings).
Well for some weird reason it only work in centered mode not in preserve the aspect ratio.On some FreeSync models interpolation (scaling) on the monitor is not supported with FreeSync active. You should be able to use GPU scaling instead as covered in this article - https://www.amd.com/en/support/kb/faq/gpu-68. So you'd need to set 'Scaling Mode' to 'Maintain aspect ratio' (or whatever they call it in the new AMD Radeon Settings).
i've seen one in person. did an A/B comparison for a very very long time in a store. the 21:9 seems perfect balance of a fit for use monitor. i googled 32:9 for a few games and programs i used and too many of them required edits of files and i just know i'll end up fiddling more than i will enjoying it.
my 2080 just about powers my 34 inch ultrawide to decent graphical fidelity so...
32:9 felt horrible to work on though but felt amazing for gaming. if i had a 2080ti, i think i may have went for this but as it is, i don't want to give up ultra or high fps for it just yet. also i felt hard-done by paying the extra resolution cost which was for most games huge distortion in games (i demo-ed many games).
My experience is actually the opposite 32:9 is amazing to work on ( I use it as a 16:9 main central window with two smaller on each sides ) but way too big for gaming.
I have played a bit of the division AC Odyssey and the latest tomb raider in 32:9 and the extra width is not really bringing anything to the table, to the point that now that I got it to work I find playing in 21:9 more enjoyable.
I agree with you that there a re still a lot of quirk to work out and that a 21:9 might just be better to game on.
