Ryzen 3 pricing from OCUK
13 Jun 2005
Cider Country
I presume there going to be Bundle upgrades available. Any idea how long before we see those?
I really should just buy the bits, but I found I'm getting (even more) lazy in my later years. ;)
OcUK Staff
17 Oct 2002
OcUK HQ
Get some of that 8Pack stuff :)
Well X570 is much better and easier to hit ram clocks on with a wider range of IC so even cheaper stuff at £60-80 should run 3200 at say 16-18-18-36 like the cheaper team and corsair ram.
8 Pack stuff is best as its screened Samsung B die and we recommend the 3200 and 3600 dual kits which will let you run say 3200 a low as cas12 if lucky and 3600 around cas14
For me personally if I was planning a high end rig with no holding back I'd grab:
3900X
Asrock Taichi X570
32GB 3600mhz 8 PACK RAM 4*8 so a pair of 16Gb kits
Corsair Gen4 SSD
5700 XT or 2080Ti
Would be foundations of my build.
21 Jun 2018
Ashton
3900X
Asrock Taichi X570
Corsair Gen4 SSD
5700 XT or 2080Ti
That sounds really solid imo.
Caporegime
1 Dec 2010
Welling, London
3900X
Asrock Taichi X570
Corsair Gen4 SSD
5700 XT or 2080Ti
Yes but the likelihood of being able to actually order that today are probably zilch :p
26 May 2008
3900X
Asrock Taichi X570
Corsair Gen4 SSD
5700 XT or 2080Ti
Sounds good to me, I don't need all of the cores so I'll probably go
3700X
Asrock Taichi X570
16GB 3600mhz 8 PACK RAM 2*8
Corsair Gen4 SSD
My existing 1070 which may be sold and swapped out for a 5700xt depending on price
Caporegime
18 Sep 2009
Dormanstown.
3900X
Asrock Taichi X570
Corsair Gen4 SSD
5700 XT or 2080Ti
Can't see any reviews of this Gen 4 Corsair SSD, but I'm assuming its because of no PCI-E 4 till 4PM.
