Caporegime
@Raymond Lin Looks good but I recon the paintwork has faded a little. I'd be tempted to go over the whole car with a light polish on a DA, something like Megs 205.
interesting - would a phone with a xenon flash fix that ?It's the flat light in the petrol station. Same phone
It does have some hazing (see in particular mid bonnet by the reflected light) and definitely plenty swirling but I'd agree that it isn't faded. Still better than mine in anycase! Almost likes your yours has some ppf on the front bumper, or is that just my eyes.
Finding time is a nightmare, definitely agree there. You can spread it out over several days though - paint wont get horribly recontaminated after 1-2 days driving. That way you just need to give it a quick wipe over (ONR is really good for this, your standard shampoo in a spray bottle) then start polishing your panel for the day. Took me several hours over 3 days to do the turd of a Peugeot I had a little while ago - worked out perfectly fine.
I have access to a garage but I need to drive the car every day including weekends so having a garage doesn’t help in that regard.
I feel like it won’t ever get done unless I get a 2nd car.
Why would that help? You won't be driving the second car while you are polishing the first one!
It will be in the garage away from the weather while i can do it over a few days and drive the other one.
You have a garage with room to move around the car and you dont use it?
Can I use it?
It even has an inspection pit...i am not kidding.
It's an old house.
You... Why... Oh
its's hot to consider DA work anyway .. products going to be dry in no time and used up quicker.Finding time is a nightmare, definitely agree there
whose the manufacturer then ? given recent thread on after-market BM head units.it just replaces the stock screen in my 3 Series with a bigger one
Front bumper resprayed . Had some lacquer peeling and an outrageous amount of stone chips for a 4.5 year old car, but sorted now and looking much healthier for it.
Now then, do I sneak in a remap before Silverstone Classic
