The R7 3700X may as well be the R7 3700. Not sure why they've confused everyone by dropping the "one non-X, one X per tier" rule (OEM chips and the original 1800X excluded).Is there going to be a 3700 non x? Seems weird there is the X but no X
Very nice. What cooler and temps?Been trying out the 3600 today.
Under Intel Burn Test at stock the boost is a solid 4.05ghz. In my experience this is the worst load a CPU can get.
Very nice, thanks.NH-U14S, ambient of 29C. Peak cpu temp of 71C under Intel Burn Test. So more like 65C with normal ambient temps.
About to see if I can overclock to 4.3 or 4.4ghz. Been testing memory stability for an hour as I don't have the best of kits at the moment.
Using a B450M Pro4.
Very nice, thanks.
I don’t suppose you took note of the batch before installing the did you?
So is that overclocked or at stock and using PBO/PB2 (whatever it’s called today lol)?
Got mine installed, first run max temps hit about 68c under AIO. Will run some benchys and games later on tonight when have time. Now just need an exciting GPU to launch xD
Ryzen 7 3700X
Radeon Nano
16GB Hyper X RGB 3200Mhz
960EVO NVMe SSD
Fractal Node 804
Lenovo 1440P
BENQ 4K
Nice what memory freq are you at? 3600 makes a big difference.
Very nice, hope mine can do the same!Well Micron E-Die is running well on the R5 3600, just need to mess about with it a bit more. 3600MHz seems stable, with 1.375v, and 16-20-16-35, not bad for 32GB dual rank DIMM's, at a cost less than 16GB 3200MHz of B-die 8Pack RAM![]()
Unfortunately looks like 4.3ghz isn't possible with 1.4v set in bios (1.35v in real life under load).
So the gamersnexus review may hold true where they required 1.43v to get 4.3ghz. The worst dies are being put in the 3600 which would make sense.
4.2ghz which is the max turbo of these chips is easy though.
Need someone to try a 3600x now.
Got a 2x8 GiB set from the same place for the missus. £57!![]()
R15 and R20 results are not comparable (I get 3500 on R15 and 7800 on R20).
