yeah. basically with good vrms, can just let PBO do its magic with a core offset voltage of -0.1v ish (PBO gives way to much voltage)Lol I found that list after I asked that question then added it to post
not sure. 3200 should definitely be okay with ryzen 3000's improved memory controller...3600 probably okay, but just a wild guess here...Ta, do you think just popping in 3600mhz ram will be no problem on these b450 boards?
yessweet spot
correctdownclocking it wont be an issue
I bought 3200 edition and am hoping to do the opposite and of it to oc 3600 if possible with whatever 3000 and mobo that I buycheers
You might want to hold off on the tomahawk for a bit, it seems msi are re releasing their b450 boards with a bigger 32mb bios chip, right now they are 16mb chips with a lite bios to be able to support older ryzen chips as well as the new ones .
Only tomahawk or Gaming carbon pro AC as well?
Just saying older CPU's not usable.
I'm a bit gutted, considering sending my gear back
a bit over-dramatic? MSI website says it's the trash-end cpus that will not have support.
need more sweets with 10 gajillion e-numbers in themi'm like a giddy child.
