Yes, hump the bar, hard.
OK mate, cheers. Butt breaks first right? Like, push butt back and the legs will follow through?
Awesome work mate, excellent progress, enjoy the summer and then clean bulk away.
More hip hinge / glute smash needed. Hinging back in to the movement is the eccentric, focus on loading up the hamstrings here, and then you really need to slam the concentric as well, firing the glutes and thrusting hard. Try to maintain a neutral spine all the way up including your head, so chin down.
Here is my RDL's from yesterday, just for reference on the points I am making.
Indeed, reference only, not perfect form! the hinge, hump, and neutral head position are the important bits.I'd say you're hyper extending a touch there on some
Eventually I shall increase the weight, but as my last movement, the focus is all about feeling it in the hammies. To much weight and the focus moves away from the hammies and into the lower back.Put more weight on there, you won’t be humping it quite as hard then
Yes, butt back. It is a very useful cue to apply to deadlifts.
To be fair your form is decent. Decent enough not to worry about overthinking it and to add some more weight. I start with my hips slightly lower, but your positioning seems to work for you. Hard to tell, but it looks like your heel is unloading slightly mid lift. Fine as long as you aren’t loading your toes.
Cheers
Gotta be honest, I never really feel it in my hams, only really with the stretch on the eccentric... maybe the extreme humping you suggested will help that, seeing as it's all in the concentric there.
Will do taken this week off due to tennis elbow and having had a cortisone injection Monday.Now go ruff them up a bit
It is the same old knee issue, but they never found a route cause to the problem and there’s a cause for everything, and a potential fix/focus to improve it which I want to work on.Perhaps it's the old knee issue that you had where you was doing bosu balance crap?
Unless that wasn't you knee.
So, randomly got on to pistol squatting due to my daughters ice skating hobby. Thought I would it a go, and surprised myself, I can hit pistol squat on my right leg, as soon as I attempt on my left leg, as soon as my knee breaks in to the movement I get pain.
The pain gets more intense the further in to the movement I get. Oddly enough I do not get this pain during normal squats, now I am concerned this might be due to my right leg doing a lot more work to compensate without me realising.
Any thoughts on what the issue might be with my left knee, could it just be weakness in my left leg that then just forces more pressure on to the knee joint itself or something more?
Brain, tbh - you've probably never physio'd out the issue meaning your brain still thinks there is an issue with the tissue (yeah - it rhymes) and registers pain where there isn't actually a problem.
I will check it out, my pain is directly through the centre of the knee horizontally so might not be the same, could still be some useful info.Funnily enough, if you're on Instagram check out squat_university's newest post because it deals with an athlete suffering from exactly that issue (pain above one knee when pistol squatting). Might not be what you have but gives you some idea of what you could screen for.
