It has multiple security and entry alerting mechanisms. I've just not mentioned them in the threadI would be so paranoid that it would get broken into
I haven't as strictly speaking it's a glorified shed with a PC in it.I'm thinking of doing something similar in the future and I was wondering if you have to declare it seperatly on your insurance?
It's been a long time since I've touched anything in my cave or network so this summer I've decided the cave may finally get finished. Gutters and brackets etc are bought and just waiting to get hold of some fascia boards now.
In the mean time I've had an attic network tidy up and took it from this the image further up (or in spoiler if you want a quick look):
To this:
I'm much happier now, although it's in the attic it was seriously making me wince at the mess it was in.
How does the CRS328 perform? I was seriously looking at getting one before chickening out due to reading a lot of varying reviews on the smaller models and getting a juniper EX3300-24P for £50 more.
Not sure if you picked up my reply in my server project thread so here it is.So to come!
New HDD for the storage server (the heat recently has more or less killed 2 of my 4 Seagate 2TB's so am going to swap for "a" WD Red as RAID isn't really needed).
Kryonaut paste due as I'm hoping to get the 8700K up to 4.8Ghz (no delid)
Dell G-Sync monitor on it's way for some eye candy upgrades
Fascia board being measured and delivered soon, I am determined to get this the guttering done and down into a water butt
New desktop on the cards, touch longer this time as I want to re-purpose the "old" screen onto the desk for a hot desk to use with laptop.
Lots of cabling to get right for the storage servers, wanting to set up at least dual links or each for balance-alb
10G upgrade (looking at you for inspiration @Kei ) ??
I was seriously considering another intel x710 for the server too but it was 2.5x the cost of the solarflare/mellanox card. I tried the mellanox connectx-3 first but it was DOA and there were no others available at the time. Having got some info on solarflare from STH, I took a punt which paid off as it seems to perform very well. The x710's I bought cost £125 each and the intel SFP's were £36 each. I read a few reports that the FS branded transceivers coded to intel didn't work with x710 cards but worked ok in the older x520, so I didn't want to take a chance. The solarflare was £50 and the avago transceivers were free which is why I went that route. In hindsight, doing this again, I'd probably go solarflare for the whole lot as I could have gotten some current gen SFN8522 cards for £70 ish each which would have been a bargain had I known they were good at the time. I could also use DAC cables for the short <3m connections as the transceiver brand is unimportant with solarflare. If I ever want to expand from 4 SFP+ ports, I plan on buying a MikroTik CRS309-1G-8S+IN and having twin uplinks with my juniper, though I doubt I'm going to need more than 4 ports for some time.Sorry to ask but you've kind of done the upgrade that I am wanting to do.
You've used Intel X710 cards into your machines apart from the server which has a Solarflare, any reason you didn't go with another Intel?
I have my main PC, Fileserver, ESXi box with the VM's pulling from said file server and Backup machine all needing to be lashed together (thinking something MikroTik in the middle of them all) but have been really holding off as I don't know what hardware to put in or of it will work.
Then will run a 10GB backbone from the MikroTik switch in the cave to my "core" switch in the attic to widen the pipe for futureproofing.
So....Intel SFP+ cards & SFP's, what kind of pricing did they work out at?
I've essentially finished getting the necessary hardware and done the testing which shows a few throughput issues that seem to be related to windows. Probably caused by my unwillingness to move from 1500byte MTU as I want a simplistic network config with no need create a separate 10Gb vlan and to fragment packets at the switch or router in order to access the outside. I've considered doing the separate vlan and retaining the 1Gbe copper connections on all the machines in order to maintain easy internet access for these machines with no packet fragmentation and inter vlan faff. The gear can do all that, however, my networking knowledge doesn't extend that far. I reckon that I'd probably get the full throughput with a 9000byte MTU, but 7Gbit/s is good enough for me as most transfers are going to be limited by other buses. I'm pretty sure that my LSI 1078 based raid controller card is limited to around 8-900MB/s anyway as it's an antique and really needs to be upgraded as it's limiting me to 2TB disks.
On the hard disk front, personally, I only use enterprise disks now. I've literally just bought a pair of WD ultrastar drives (4TB & 6TB) for two of the pcs and once I replace my raid controller, I'll probably move the server up to 8TB disks. I've been using WD Se drives for nearly 6 years now and they've survived being in the loft and in my pc.
You'll most likely find that with link aggregation, you'll only benefit if you're talking server to multiple workstations. Server to single workstation will only get 1Gbps. You may even be better to not aggregate them and let SMBv3 aggregate the links itself....if that is applicable. Other complexities with that as you end up with a multi-homed server.
Great project.
If we dont move, then I've a load of plastering to do again
Really nice mancave.
STILL subbedGreat project.
Loving the direction, especially the conversation re: 10Gbe. I've bought (and fitted) 2x 10gb cards with rj45 sockets on them.
trying to eek the last bit of performance out of my cat5e wired lan before I have to rip it all out to upgrade.
Next is the switch to be upgraded.... I know it wont give me 10gb speeds due to the cables, but >1gb is better that nothing, plus when we move house I'll wire in something higher spec.If we dont move, then I've a load of plastering to do again
I've just checked on what a 10Gb ethernet switch would be in my preferred flavour and my eyebrows just about fell off! It;s going to have to be a staged rollout but the problem I have is I need both PoE and 10GB in the cave and the switch to do that is £400 which is a difficult one to stomach when at the moment I don't utilise the Gb I have more than 2% of the time (and then storage speeds will hold me off). Would like to do fibre to my desktop though...
Could you do it with two switches? 10Gbps backbone with gig PoE switch hanging off it? You can pick up something like a Netgear GS305P for £40 - maybe less with some shopping around.
