I pre ordered it with OCUK since I am hoping they get stock sooner. Gibbo was meant to get stock today buy truck driver has gone missing lol
it seems rocking horse brown stuff would be easier to find at the moment then these CPU's. Great launch
it seems rocking horse brown stuff would be easier to find at the moment then these CPU's. Great launch![]()
My preliminary thoughts on the Taichi:
- My bios came as v1.10
- Glad that the RGBs have quite detailed controls in bios (didn't want to install extra software)
- Default SB fan was unbearably LOUD (4500rpm+) and none of the fan control settings worked, my pc is right next to me and all my fans are normally <1000rpm so dead silent normally
- Updated bios to latest non beta (1.40), fan controls now work (bios fan utility is awesome)
- SB fan is inaudible below ~2500rpm so I'm happy
- was able to set my ram (Crucial 16GBx2 bls2k16g4d32aese) straight to 3600c16 first by enabling xmp and then bumping up the Freq and voltage to 1.375v, currently testing stability
Edit: the only slight annoyance I have is the SB fan still starts off at 100% on boot for a few seconds while the bios loads
T-top is better with 4 sticks?
It's better, but 2 sticks in daisy chain will generally clock higher I think. Since 3600 seems fine for Zen 2 it's kind of irrelevant though.T-top is better with 4 sticks?
Yeah that works for me I've got 4x16GB 3466mhz so hopefully will get them to 3600Mhz on the Taichi. Seems to be the sweet spot before the IF divider kicks in.
Beggars belief they have these chipset fans going all out big guns right off the bat. We were all under the impression they would only come on when needed, and that would only be under heavy heavy NVME loads. Genuinely would be enough to push me onto Z390 if the bloody mobos have a stupid little high pitched fan screaming it's nut off.
Send this to ASROCK.There appears to be a bug in the bios, not sure if anyone else can confirm (using the latest 1.60 bios). If you load your XMP profile and then change your ram speed, the IF frequency remains locked at the initial speed even though the ratio is set to auto (which should mean 1:1). I was using ryzen master to check the ratio
Edit: Also at stock settings, my 3600 was idling at 50c and hitting 90+ in prime 95. I'm now down to -200mV offset which seems to give reasonable temps
I was all set for a Gigabyte but £242 was too good to pass up. Still like the look of the Aorus Master though![]()
I've still to hear of anyone actually receiving these supposedly cheap boards. Have 2 friends will all components ready to go and no board.
