samame board as me can u tell me what bios version you are using thanksGot my 3700X today, running it on an Asus X470 Prime Pro. I had updated the bios before hand so the install went incredibly smoothly and everything is up an running great. I would say however that on auto-voltages on this motherboard, its sitting at 1.45v idle which from what I can tell is normal behavior for Zen2 however its still higher than I have liked so I have set a negative offset in the bios and I have done some benchmarks and I have lost no performance while dropping the max idle voltage to 1.330V vs 1.450v.
). I know they boost higher than that one their own but it's for very brief periods and there are a lot of things being figured out everyday. Not saying 1.4 isn't safe but until things have matured a bit I would personally go lower.
