Thanks for that. Great performance there. I’m happy I’ve got a great chip for DAW use too. As in other applications, the 3900 is still trading blows with £1000+ HEDT intel CPU’s.
Looks great doesn’t it?
Just watched this. Not particularly good review for the 3700x. It's not a bad CPU, it's just for the money depending on workload your money might be better spent else where.
In sum, 3600 excellent chip for the money and good at gaming. 3700x odd placement in the market due to better CPUs for the same money dependant on workload. 3900x has a place as a entry level HEDT chip.
Yes, 6 cores has been the sweet spot for a year or two now and it's always been the case that more cores is diminishing returns. If you're only gaming, the only real reason to get an R7 3700X instead of an R5 3600 is future proofing. But that was true of the i9-9900K v i5-9600K too.Its a weird review. He talks about gaming being too close for the Ryzen 7 3700X compared to the Ryzen 5 3600 which is a fair statement,but the forgets this:
6 core CPUs relative to 8 core CPUs have most of the gaming performance for less money. You are only buying an 8 core CPU in a gaming rig for being futureproof,ie,next generation consoles,etc. The performance is not reflected right now,ie,games being unplayable.
yeap, good example of why don't follow this chanel: full of himself, hardly interested, can't even read the text and figures properly and ye elephant in the room (anti amd bias). Did learn the tricks of msm quite well need to admit, like tossing and playing ( with real figures) just to fit his narrative, one word - Twatt
Added another review for the Ryzen 5 3600:
https://www.pugetsystems.com/pic_disp.php?id=55963&width=800
Tests Adobe software.
This is almost certainly a BIOS bug that only applies to certain motherboards. Ryzen Master always shows my IF at the same frequency as my DRAM, so clearly the "auto" setting works fine on mine.Apparently decoupling the Infinity Fabric and set it manually improves the performance. Somehow there is a bug where IF works at reduced speed even at 3600Mhz
https://old.reddit.com/r/Amd/comments/ccsh2v/has_anyone_tried_this_potential_gaming/
The gaming perf boost can be up to 10%!
