I just need a car that isn't going to break down and will carry an MTB around.
I'm fed up of spending 4k on a car then having to spend a ton of money fixing it.
1.9 tdi's never dieBrought a Fabia Vrs 6 years ago for £2600 and it’s never broke down on me and only ever needing to replace parts due to wear and tear.
Buying a car is always a gamble and you can have more expensive issues with a newer depending on your luck I guess.
I work in the trade and quite often see new cars having major work as in gearboxes and engine replacements. I’d rather swap an engine in my 14 year old car than a new one.
what on earth are you doing to them !
my cars have cost me between 3-5K , all been ok, current one, cost me 5K , 5 years later still going strong, just the usual brakes/tyres/oil
Except for turbos everything else on the list is a wear item... what mileage are you doing and how high mileage are these cars when you get them?List of cars I've had
MK4 1.9 TDI PD
Audi A3 2.0 TDI PD
Another Audi A3 2.0 TDI PD
Seat Leon FR 2.0 TDI PPD
Passat CC 2.0 TDI CR
all of them seem to constantly break, wheel bearings, bushes, mounts, shocks, turbos.
Gearbox's and engines have been great, apart from the CR which ALMOST had an oil pump failure.
j
There around 90-110k and I'm doing around 7-10k a year.Except for turbos everything else on the list is a wear item... what mileage are you doing and how high mileage are these cars when you get them?
DomBruv said:...all of them seem to constantly break, wheel bearings, bushes, mounts, shocks, turbos
DomBruv said:There around 90-110k and I'm doing around 7-10k a year.
150-250 a month???
What on earth death traps have you been buying haha
what car atm?
I'm a chav that joined the forums when i was 14 m8*checks OP's username*
Or a BMW?![]()
How comes your preference is Diesel, when your not doing higher mileage? I would personally go petrol for the next car.There around 90-110k and I'm doing around 7-10k a year.
Yeah I was thinking this tbh but I just can't decide what,
and there are a few reasons why I always go for the VW TDI tbh.
I'm not doing massive miles at the moment, but i plan to travel around England with the bike a lot this and next year.
So around the mileage range that you would expect wear and tear parts to need replacingThere around 90-110k and I'm doing around 7-10k a year.
Could not be seen in of those mate there ugly, and I will want some power.So around the mileage range that you would expect wear and tear parts to need replacingI think we have found our problem.
Also go petrol, and go N/A, removes turbos from the equation and even on long journey's they perform just as well as diesels. I do roughly 8k miles per year, 90% of those around town, and hit 40mpg average per tank. I drive a Honda civic 1.8.
They have enough power for our roads unless you want willy waving numbers. More importantly their balance of power to fuel economy ratio takes some beating.But equally you want reliability - you can't have it both ways? (Because buying tired old german rep mobiles has worked well)
As for power 1.9 and 2.0 TDIs are hardly the last word in power?
