You need to post in the Customer Services Forum - Pre-Sales Advice. Link to this thread once you've finalised your build and you'll get to discuss the finer details with them.how do i get overlockers to build me a pc build i have chosen? cant see the option for custom build on website
thanksYou need to post in the Customer Services Forum - Pre-Sales Advice. Link to this thread once you've finalised your build and you'll get to discuss the finer details with them.
They do it all the time and the staff that run them are great - ones i've dealt with anyway (within customer services).
@Chaze - did a quick search on your build, i can only assume costs must have gone up, as that's a very simple build (if you opted for similar build in opening post with no Windows install?)
@orbitalwalsh @Danny75 - have build costs shot up? As we're guestimating wrong looking at Chaze's build cost and his component choice and no Windows install required.
@Plec with regards to build fee, I was just charged £118 for a very similar spec (AIO instead of air cooler).
Not happy tbh but not sure if I was robbed or this is now the norm.
Cheers Orbi, yeah covered it with @Danny75 - makes sense - just more expensive than i expected (rarely get feed back on build costs once specced).>build costs<
I can't believe that came from your fingers (has someone-else taken over your account) - that's usually my mantra - have you turned to the 'light' side?AIO more of a pain to fit and 100% chance of leaking vs an air coolers zero
only eisbear 360 AIO can match performance of flagship £70 air cooler
yeah ive always gone overkill with power supplies. well heres to hoping it arrives safely. thanks again you and everybody for your comments and suggestionsYep, you don't buy anti virus software - i only use Windows Defender.
That's a lot of power supply.
No worries you compiled a tidy build - it will certainly power its way through your gaming genre.yeah ive always gone overkill with power supplies. well heres to hoping it arrives safely. thanks again you and everybody for your comments and suggestions
gone with this guys
Phanteks Eclipse P600S Silent Midi Tower Case - Black
AMD Ryzen 7 3700X Eight Core 4.4GHz (Socket AM4) Processor - Retail
igabyte X570 GAMING X (AMD AM4) DDR4 X570 Chipset ATX Motherboard
Hydro Series H75 Performance Liquid CPU Cooler - 120mm
Gigabyte GeForce RTX 2070 Gaming OC 8192MB PCI-Express Graphics Card
Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit
Corsair Force MP510 series 960GB NVMe PCIe M.2 Solid State Drive (CSSD-F960GBMP510)
Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD
Corsair RMx Series RMx850 850W '80 Plus Gold' Modular Power Supply
ms windows 10
total £1775 (not included build/delivery)
Not bothered about internet anti virus not had an anti virus software in 6 years. Not got a keyboard already got a g710+, mouse happy with a budget gaming mouse i got years ago. Not got a new monitor yet need to do more research on a new IPS monitor
2070 Oc gaming edit it appears I selected that by accident oh well guess it is what it is
i got the gigabyte gtx Geforce 2070 gaming OC![]()
No matter - it is what it is.2070 Oc gaming edit it appears I selected that by accident oh well guess it is what it is
That said, you may have the option to change (won't have been built) - not hard for them to swap out, but would need to wait for stock/release (TBH, this is why i thought you had swapped it out from my spec list).
As for 3600MHz over 3200MHz minimal gains - and money better off put towards that monitor. And while @orbitalwalsh is lurking it would be wise to pick his thoughts over a decent 27" 144Hz gaming monitor (Max budget needed).
Only had a token look - via phone so killed my eyes...depends on the game .
https://forums.overclockers.co.uk/t...-2133-2400-2933-3200-3733-4000-4200.18860401/
if every one keeps going on about next gen console moving forward PC Gaming on multiple cores then we should see effects of BFV - but have feeling half of them will be poor ports as usual lol
