the thing is most people only do one socket change per upgrade. realistically most people even on amd will buy one cpu and mobo then change the lot again when its upgrade time.
3570k was £190 on release day and afaik never dropped. I don't feel I could have spent less than the £50 I did on a cooler.... get away with the 2500k/3570k which was a £150 cpu - so it's not too far different, "if you are just into gaming"
ah yes, you're right (kinda). went delving into my past ocuk orders. 3570k was £180, 3770k was £2503570k was £190 on release day and afaik never dropped.
I mean what are they going to do? Price to compete with the product they stopped making?
2000 will leech some sales but they will fade out of the market eventually.
So, regarding AMD becoming more expensive, prices seem in line with the Zen+ release....
Ryzen 7 2700 for £155-£180, which can be OCed, is the best buy and no Ryzen 7 3000 will be good unless AMD put the price around 200 quid, as well.
Ryzen 3000 does give only small IPC increase and no MHz increase whatsoever, Ryzen 7 2700X vs 3700X is only 13% IPC increase and 0-50 MHz more.
This is the type of update that intel has been widely known to offer for a decade before March 2017.
i7-6700K -> i7-7700K is the same performance update.
No one in their right mind will or should upgrade from 2700 to 3700X.
You're talking out of your rear, the IPC increase from 6700K to 7700K was 0 They are the same CPU.
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Core+i7-6700K+@+4.00GHz&id=2565Nah, look at the Passmark scores at stockhttps://www.cpubenchmark.net/cpu.php?cpu=Intel+Core+i7-6700K+@+4.00GHz&id=2565
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Core+i7-7700K+@+4.20GHz&id=2874
Great post Humbug.The 9600K stutters like a skateboard down a flight of stairs in a couple AAA titles at 1080P on an RTX 2080TI, i know one might say that's an unreasonable setup but when talking about longevity it's not, it's going the same way all the other i5's have, the 7700K isn't quite there yet, why? SMT.
The 9700K, a £380 CPU has two more cores, threads, 8 of them, the 8700K will outlive the 9700K as useful high end gaming CPU, hell my 3600 will outlive the 9700K.
The 8700K was and still is a very good CPU, the 9700K already isn't.
Intel, as always give you "just enough" on the day just one step below the highest end, the 8700K was the only exception to that rule.
Great post Humbug.
I decided to upgrade my 2600K for a Ryzen 2600 which was delivered today. I couldn't say no to the price for under £120 so no 3600 for me this round.
So I now have a 8700K, 2600X and a 2600. The 2600K was hitting 100% usage in the GEARS 5 tech test and the 2600X was 40-50% with similar fps so I know that the 2600 will satisfy my needs.
Just you to be aware that AMD is intel №2, for our horror![]()
its just down to what you do on your pc on a decent modern cpu its probably not worth upgrading to the new amd cpus just for gaming.
1080
2700x stock vs 3700x in pubg. 103 fps vs 108
5820k stock vs 3700x in pubg. 98 fps vs 108
8600k stock vs 3700x in pubg 106 fps vs 108
7700k stock vs 3700x in pubg 105 fps vs 108
6700k stock vs 3700x in pubg 103 fps vs 108
a decent 5820k will overclock possibly 1ghz on top. so thats same as a stock 3700x ingames or slightly quicker.over clock the 2700x and its a stock 3700x performance in games. so at this point and time if you gaming make sure you check numerous reviews or you could end up with worse performance than you already have.
Look at it this way, the 2700X is 2% slower than a 7700K, do you think that's entirely the CPU, or is the GPU the bottleneck here?its with a 1080ti
