What does this fix? Should I be using this over 1.60?As said 3700X is 8 cores and probably the pick of the bunch for me.
Nice comparison here:
https://www.pugetsystems.com/labs/a...9th-Gen-Intel-X-series-1529/#BenchmarkResults
Was that meant to be for me Beany? If you are talking about the BIOS it brings a newer AGESA version, IF fix, and other fixes that I don't know. They just told me "try this version, it has many bug fixes"What does this fix? Should I be using this over 1.60?
So why on earth haven't they rolled it our properly??Was that meant to be for me Beany? If you are talking about the BIOS it brings a newer AGESA version, IF fix, and other fixes that I don't know. They just told me "try this version, it has many bug fixes"
I didn't ask them that part haha But I am using it and it works really well. AGESA 1.0.0.3AB is the official version that fully supports Zen 2 as far as I know, and 1.65 has it.So why on earth haven't they rolled it our properly??
Ok I'll install once I sort all my drives out thanks.I didn't ask them that part haha But I am using it and it works really well. AGESA 1.0.0.3AB is the official version that fully supports Zen 2 as far as I know, and 1.65 has it.
No problemOk I'll install once I sort all my drives out thanks.
Not sure if this has been posted already, but if anyone else is noticing high SB temperatures even when sat idle or in BIOS - check the heatsink and fan assembly under the M.2 shield.
I noticed that the one attached to my board seemed loose, in that there was a few millimetres of movement from side to side when touching the heatsink. There are 2 screws on the back of the board which secure the heatink to the board, I tightened those up and now have SB temperatures in the low 50s when idle or in BIOS, whereas before just sitting in BIOS would see the temperature creep up over 70C and keep going up.
I wasn't experiencing any random shutdowns but I hate seeing unnecessarily high temperatures, especially when it's a result of something which seems like simple, poor quality control.
The 3700X is 8 core 16 threads, same as the 3800X, they just have different clock speeds.
The 3600 and 3600X are 6c/12t.
Nope, both are eight cores. The 3600 and 3600X have six.
I'm using the stock silent preset and it's currently idling at 57C, went up to 63C earlier during gaming, can't hear the fan at all now. It's a massive improvement from the 70C idle and 85C+ that I was seeing when gaming, with the fan running at full tilt. I was on the verge of going through the hassle of returning the board under DSR because of it, but I'm happy now.What fan setting do you use for PCH chipset?
I'm idling at 62c in todays hot weather with the PCH fan set to off. I have set it to go to 40% when temps go above 75c.
Question, has anyone had an issue with the USB-C front panel connector being blocked by a GPU on this board? I am hesitating over the X570 Taichi, MSI Meg Ace or the Aorus Master. Main concerns are chipset fan noise/temps and if the USB-C cable will be blocked.
So why would you order the 3700x over the 3800x in repsect to each chips TDP?
Never mind I was looking at the wrong thing on HWInfo. Mine shows 59C, and its pretty hot today.Are you sure you're measuring the correct sensor? That seems very low. In HWMointor it's SYSTIN. In Asrock Motherboard utility/A-Tunibng it's listed as SB Temperature.
