Hi folks, hoping to upgrade within the next few weeks. Likely when the custom coolers come out for the 5700 GPUs.
Would most agree going from a 4770K be a worthwhile upgrade to the 3600? I've researched plenty already on the 3600 vs 3600X vs 3700X etc. Everyone seems to say for gaming only, the 3600 is a no brainer...
I'd appreciate any thoughts on the spec or suggestions? Looking to front-mount the AIO CPU rad/cooler, then use the 120mm fan on the case rear to suit.
Current Specs:
Intel i7 4770K (with Corsair Hydro H110 AIO)
ASUS ROG Maximus VI HERO Z87 (Socket 1150)
AMD Vega 56 GPU
16GB Kingston HyperX Savage DDR3 2400MHz
Samsung 850 EVO 500GB
Samsung 840 EVO 250GB
Seagate 3TB HDD
Corsair Carbide 330R Case
I game on a Dell S2719DGF @ 1440p. Don't mind turning the odd graphic setting down to keep my FPS healthy.
This is what my basket is currently looking like. As you can tell I'm going for a fairly white theme
Gutted I can't find any nice white X570 mobos, there is the Asus ones but I'm not keen on them and I think they have less power phases.
The GPU is a placeholder for when the custom coolers are released (mid-August I believe?).
My basket at Overclockers UK:
(also be buying this Corsair RMx 850W White PSU to match the theme
Current Specs:
AMD Vega 56 GPU
Seagate 3TB HDD
- 1 x Gigabyte X570 AORUS ELITE (AMD AM4) DDR4 X570 Chipset ATX Motherboard= £209.99
- 1 x Corsair Force MP510 series 960GB NVMe PCIe M.2 Solid State Drive (CSSD-F960GBMP510)= £139.99
- 1 x Corsair Vengeance RGB Pro 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - White= £99.95
- 1 x AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail= £199.99
- 1 x Corsair Carbide 275R Midi Tower Gaming Case - White Tempered Glass (CC-9011133-WW)= £69.95
- 1 x Corsair Hydro Series H100i Platinum SE Addressable RGB Performance Liquid CPU Cooler - 240mm (CW-906= £139.99
- 1 x Corsair LL120 RGB, 120mm Dual Light Loop RGB LED PWM Fan - White= £24.95
- 1 x Gigabyte Radeon RX 5700 XT 8GB GDDR6 PCI-Express Graphics Card= £398.99
