ASROCK X570 TAICHI - THE RYZEN 3000 MOTHERBOARD GIBBO & 8 PACK RECOMMENDS
I been using a spare 1080ti FE and these things get spicy! No problems though. Although it did get hot! Then again. The card runs at 80c so...
I wacked a hybrid AIO kit on it and whole thing is generally much cooler. I'm going to cool watercool the whole things soon so won't be a factor anyway.
So nobody has been having issues with it getting hot enough to shutdown the machine with a long GFX installed? Just curious cause i like the price point of this MB (want the 3 pcie slots for VM work) and that was a concern i saw pop up in some other communities comments.
No, but it was hotter than I would have liked. Apparently the SB chip on these Asrock boards has TJMax of 105C (not confirmed but I saw it in a YT video, and didn't experience any shutdowns when heading towards 90C before I fixed it). If you do get one make sure you check the SB heatsink is secured properly to the board.
I've just bought this motherboard elsewhere at a reduced price. Now I just need to decide on case, Air cooler and CPU. Part of me is saying to just go all out on the CPU now so it lasts longer between upgrades or go with a 3700X now and look at changing with Ryzen 4xxx.
Was the reports of overheating from the board a fairly isolated case? Did they ever get to the bottom of it?
I've not had a new motherboard in quite a few years so I'm hoping BIOS layouts have improved. I don't tend to spend much time in the BIOS anyway but ease of use is beneficial for me.
If you’re mainly gaming then 3700X now then something with greater single thread performance next year seems a smart move.
I decided just to cancel for now and wait it out a bit longer until BIOS updates become more stable and prices settle a bit.
a voice of reason in a sea of insanity :p
you know what'll happen though don't you, you'll wait and wait then think - hmmm, might as go for the 3950x ;)
Haha well that could happen!!
It just did when I was looking for a 1050 laptop. I've gone for a 1070 equipped one instead :rolleyes:
I think I would feel happier once the new components has been out in the wild a few months. That allows all the more 'in the know' people on here to suss out issues and hopefully be able to assist if I get something wrong.
Hi there
So This Week Only (until next Wednesday) we are running some great deals to make your Ryzen 3000 upgrade, DIY rig build that bit cheaper so we have discounts on CPU's, RAM, Motherboards, SSD, Graphics etc, so check out the products below, they are all what we recommend for building a Ryzen 3000 machine and were using the most popular of the CPU's, the 3700X. :)
AMD Ryzen 7 3700X Eight Core 4.4GHz (Socket AM4) Processor - Retail @ £299.99 inc VAT
100-100000071BOX, 8 Core with 16 Threads, 4.40GHz clock speed, 7nm FinFet Process, 32MB L3 Cache, Dual Channel DDR4 Controller, 3200-3600MHz RAM Recommended, 3 Year Warranty
Only £299.99 inc VAT.
ORDER NOW
AMD Ryzen 7 Eight Core 2700X 4.35GHz (Socket AM4) Processor - Retail @ £229.99 inc VAT
YD270XBGAFBOX, Eight Core with Sixteen Threads, 4.35GHz clock speed, 12nm FinFet Process, 20MB L3 Cache, Dual Channel DDR4 Controller, 3 Year Warranty
Only £229.99 inc VAT.
ORDER NOW
AMD Ryzen 5 3600X Six Core 4.4GHz (Socket AM4) Processor - Retail @ £218.99 inc VAT
100-100000022BOX, 6 Core with 12 Threads, 4.40GHz clock speed, 7nm FinFet Process, 32MB L3 Cache, Dual Channel DDR4 Controller, 3200-3600MHz RAM Recommended, 3 Year Warranty
Only £218.99 inc VAT.
ORDER NOW
MSI X570-A PRO (AMD AM4) DDR4 X570 Chipset Motherboard @ £169.99 inc VAT
Only £169.99 inc VAT.
ORDER NOW
Gigabyte X570 AORUS MASTER (AMD AM4) DDR4 X570 Chipset ATX Motherboard @ £389.99 inc VAT
Socket AM4, X570 Chipset,3rd Gen AMD Ryzen™, 4x DDR4,2 x PCI Express 4.0 Slots x16 ,Onboard Intel® WiFi 6 802.11ax,Triple Ultra-Fast NVMe PCIe 4.0/3.0 x4 M.2,BLuetooth 5, RGB FUSION,
Only £389.99 inc VAT.
ORDER NOW
Gigabyte X570 AORUS PRO (AMD AM4) DDR4 X570 Chipset ATX Motherboard @ £259.99 inc VAT
Socket AM4, X570 Chipset,3rd Gen AMD Ryzen™, 4 x DDR4 supporting up to 128 GB,Dual Ultra-Fast NVMe PCIe 4.0, Intel® Gigabit LAN, Front & Rear USB 3.1 Gen2 Type-C,RGB FUSION 2.0,6 x SATA 6Gb/s
Only £259.99 inc VAT.
ORDER NOW
Asus ROG Crosshair VIII Hero (AMD AM4) DDR4 X570 Chipset ATX Motherboard @ £389.99 inc VAT
ORDER NOW
Asrock X570 Taichi (AMD AM4) DDR4 X570 Chipset ATX Motherboard @ £308.99 inc VAT
Socket AM4, X570 Chipset,3rd Gen AMD Ryzen™, 4 x DDR4 supporting up to 64GB,PCIe Gen 4 support, 8 x SATA 6Gb/s ports, 2 x USB 3.2 Gen 2 ports
Only £308.99 inc VAT.
ORDER NOW
Asrock X570 Phantom Gaming 4 (AMD AM4) DDR4 X570 Chipset ATX Motherboard @ £179.99 inc VAT
Only £179.99 inc VAT.
ORDER NOW
MSI B450 GAMING PRO CARBON AC (Socket AM4) DDR4 ATX Motherboard @ £124.99 inc VAT
Socket AM4, Supports Ryzen 1st and and Generation, 4x DDR4 DIMM, 1x PCI-E 3.0 x16, 1x PCI-E 2.0 x16, 3x PCI-E x1, CrossFire Support, 2x M.2 Slots, 6x SATA 6Gb/s
Only £124.99 inc VAT.
ORDER NOW
Gigabyte B450 AORUS ELITE (Socket AM4) DDR4 ATX Motherboard @ £89.99 inc VAT
Socket AM4, Support for 1st and 2nd Generation Processor, 4x DDR4 DIMM, 4x USB 3.1 Gen 1, 4x USB 2.0. 1x PCI-E x16, 2x PCI-E x1, 1x PCI-E x4
Only £89.99 inc VAT.
ORDER NOW
Gigabyte B450M-DS3H AMD B450 (Socket AM4) DDR4 Micro-ATX Motherboard @ £64.99 inc VAT
Support for Ryzen 1000 & 2000 Series, XFR2 Support, 4xDDR4 2666/3200MHz, 2xPCIE x16, 1xPCIE x1, 4xSATA, 1xM.2, 4xUSB 3.0, 8xUSB 2.0, Gigabit LAN, HD Audio, DVI-D, HDMI, 12V RGB
Only £64.99 inc VAT.
ORDER NOW
Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30 @ £59.99 inc VAT
TLGD416G3000HC16CDC01, 3000MHz RAM Speed, CAS 16-18-18-36 Timings, 1.25-1.35v VDIMM, Lifetime Warranty with OcUK.
Only £59.99 inc VAT.
ORDER NOW
Team Group Vulcan T-Force 32GB (2x16GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD432G3 @ £109.99 inc VAT
TLGD432G3000HC16CDC01, 3000MHz RAM Speed, CAS 16-18-18-36 Timings, 1.25-1.35v VDIMM, Lifetime Warranty with OcUK.
Only £109.99 inc VAT.
ORDER NOW
Team Group Night Hawk RGB 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - RGB Black (TF1D4 @ £79.99 inc VAT
TF1D416G3000HC16CDC01, 3000MHz RAM Speed, CAS 16-18-18-38 Timings, 1.25-1.35v VDIMM, Lifetime Warranty with OcUK.
Only £79.99 inc VAT.
ORDER NOW
Team Group Vulcan TUF Gaming Alliance 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Blac @ £64.99 inc VAT
TLTYD416G3000HC16CDC01, 3000MHz RAM Speed, CAS 16-18-18-36 Timings, 1.25-1.35v VDIMM, Lifetime Warranty with OcUK.
ORDER NOW
Corsair Vengeance LPX 8GB (2x4GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Black (CMK8GX4M2C3000 @ £38.99 inc VAT
CMK8GX4M2C3000C16, 3000MHz RAM Speed, CAS 16-18-18-36 Timings, 1.20-1.35v VDIMM, Lifetime Warranty with OcUK.
Only £38.99 inc VAT.
ORDER NOW
Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Black (CMK16GX4M2D30 @ £70.99 inc VAT
CMK16GX4M2D3000C16, 3000MHz RAM Speed, CAS 16-18-18-36 Timings, 1.20-1.35v VDIMM, Lifetime Warranty with OcUK.
Only £70.99 inc VAT.
ORDER NOW
Team Group Dark Pro "8Pack Edition" 16GB (2x8GB) DDR4 PC4-25600C14 3200MHz Dual Channel Kit - Black/ @ £119.99 inc VAT
TDPGD416G3200HC14ADC01, 3200MHz RAM Speed, CAS 14-14-14-31 Timings, 1.20-1.40v VDIMM, Samsung B-Die, Ideal for 3rd gen Ryzen, Ryzen 3000 8 Pack Approved, Lifetime Warranty with OcUK.
Only £119.99 inc VAT.
ORDER NOW
Team Group Dark Pro "8Pack Edition" 16GB (2x8GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit - Black/ @ £139.99 inc VAT
TDPGD416G3600HC16ADC01, 3600MHz RAM Speed, CAS 16-16-16-36 Timings, 1.20-1.40v VDIMM, Samsung B-Die, Ideal for 3rd gen Ryzen, Ryzen 3000 8 Pack Approved, Lifetime Warranty with OcUK.
Only £139.99 inc VAT.
ORDER NOW
Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black/Grey (TLGD @ £82.99 inc VAT
TLGD416G3200HC16CDC01, 3200MHz RAM Speed, CAS 16-18-18-36 Timings, 1.25-1.35v VDIMM, Lifetime Warranty with OcUK.
Only £82.99 inc VAT.
ORDER NOW
Team Group Vulcan TUF Gaming Alliance 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Blac @ £79.99 inc VAT
TLTYD416G3200HC16CDC01, 3200MHz RAM Speed, CAS 16-18-18-36 Timings, 1.25-1.35v VDIMM, Lifetime Warranty with OcUK.
ORDER NOW
Kingston HyperX Predator RGB 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit @ £98.99 inc VAT
HX432C16PB3AK2/16, 3200MHz RAM Speed, CAS 16-18-18-36 Timings, 1.35v VDIMM, Lifetime Warranty with OcUK.
Only £98.99 inc VAT.
ORDER NOW
Kingston Fury Black 16GB (2x8GB) DDR4 PC4-21300C18 3200MHz Dual Channel Kit (HX432C18FB2K216) @ £79.99 inc VAT
HX432C18FB2K216, 3200MHz RAM Speed, CAS 18-18-18-38 Timings, 1.35v VDIMM, Lifetime Warranty with OcUK.
ORDER NOW
Corsair Vengeance LPX Black 16GB (2*8GB) 3600 MHz AMD Ryzen Tuned DDR4 Memory Kit @ £99.95 inc VAT
16GB (2x8GB) Corsair DDR4 Vengeance LPX Black, PC4-28800 (3600), Non-ECC Unbuff, CAS 18, 1.35V, AMD Ryzen Optimised
Only £99.95 inc VAT.
ORDER NOW
Corsair Dominator Platinum RGB 16GB 3600 MHz DDR4 Dual Channel Memory Kit Ryzen Tuned @ £179.99 inc VAT
16GB (2x8GB) Corsair DDR4 Dominator Platinum RGB, PC4-28800 (3600), Non-ECC Unbuff, CAS 18-19-19-39, RGB LED, XMP, 1.35V
ORDER NOW
Corsair Force MP600 series 1TB NVMe PCIe Gen4 M.2 Solid State Drive (CSSD-F1000GBMP600) @ £248.99 inc VAT
CSSD-F1000GBMP600, 1TB Corsair Force MP600, M.2 (2280) PCIe 4.0 (x4) NVMe SSD, Phison, TLC 3D NAND, 4950MB/s Read, 4250MB/s Write,680k/600k
Only £248.99 inc VAT.
ORDER NOW
Corsair Force MP600 series 2TB NVMe PCIe Gen4 M.2 Solid State Drive (CSSD-F2000GBMP600) @ £428.99 inc VAT
CSSD-F2000GBMP600, 2TB Corsair Force MP600, M.2 (2280) PCIe 4.0 (x4) NVMe SSD, Phison, TLC 3D NAND, 4950MB/s Read, 4250MB/s Write,680k/600k
Only £428.99 inc VAT.
ORDER NOW
Sapphire Radeon RX 5700 XT 8GB GDDR6 PCI-Express Graphics Card @ £379.99 inc VAT
21293-01-40G, Core Clock: 1605MHz, Boost Clock: 1905MHz, Memory: 8192MB 14000MHz GDDR6, Stream Processors: 2560, DirectX 12 Support, Vulkan Support, RDNA, Freesync 2 HDR support, 2yr Warranty.
Only £379.99 inc VAT.
ORDER NOW
Sapphire Radeon RX 5700 8GB GDDR6 PCI-Express Graphics Card @ £329.99 inc VAT
21294-01-20G, Core Clock: 1465MHz, Boost Clock: 1765MHz, Memory: 8192MB 14000MHz GDDR6, Stream Processors: 2304, DirectX 12 Support, Vulkan Support, RDNA, Freesync 2 HDR support, 2yr Warrant
Only £329.99 inc VAT.
ORDER NOW
Aorus 1TB NVMe PCIe Gen4 M.2 Solid State Drive (GP-ASM2NE6100TTTD) @ £269.99 inc VAT
GP-ASM2NE6100TTTD, 1TB Aorus, M.2 (2280) PCIe 4.0 (x4) NVMe SSD, Phison, TLC 3D NAND, 5000MB/s Read, 4400MB/s Write,750k/700k
Only £269.99 inc VAT.
ORDER NOW
Aorus 2TB NVMe PCIe Gen4 M.2 Solid State Drive (GP-ASM2NE6200TTTD) @ £428.99 inc VAT
GP-ASM2NE6200TTTD, 2TB Aorus, M.2 (2280) PCIe 4.0 (x4) NVMe SSD, Phison, TLC 3D NAND, 5000MB/s Read, 4400MB/s Write,750k/700k
ORDER NOW
TeamGroup 240GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive @ £29.99 inc VAT
T253TD240G3C101, 240GB TeamGroup L5 Lite, 2.5" SSD, SATA III - 6Gb/s, 3D NAND technology, Read 470MB/s, Write 400MB/s, 65K/70K IOPS, 3yr Warranty
Only £29.99 inc VAT.
ORDER NOW
TeamGroup 480GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive @ £49.99 inc VAT
T253TD480G3C101, 480GB TeamGroup L5 Lite, 2.5" SSD, SATA III - 6Gb/s, 3D NAND technology, Read 470MB/s, Write 420MB/s, 70K/70K IOPS, 3yr Warranty
Only £49.99 inc VAT.
ORDER NOW
TeamGroup 1TB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive @ £89.99 inc VAT
T253TD001T3C101, 1TB TeamGroup L5 Lite, 2.5" SSD, SATA III - 6Gb/s, 3D NAND technology, Read 500MB/s, Write 480MB/s, 80K/70K IOPS, 3yr Warranty
ORDER NOW
Samsung 1TB 860 QVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-76Q1T0BW) @ £104.99 inc VAT
MZ-76Q1T0BW, The 860 QVO is the advanced consumer SSD powered by 3D V-NAND technology that maximizes everyday computing experiences with optimized performance and enhanced reliability.
Only £104.99 inc VAT.
ORDER NOW
Samsung 1TB 860 EVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-76E1T0B/EU) @ £139.99 inc VAT
MZ-76E1T0B/EU, The 860 EVO is the advanced consumer SSD powered by 3D V-NAND technology that maximizes everyday computing experiences with optimized performance and enhanced reliability.
ORDER NOW
Corsair Force MP510 series 480GB NVMe PCIe M.2 Solid State Drive (CSSD-F480GBMP510) @ £64.99 inc VAT
480GB Corsair MP510, M.2 (2280) PCIe 3.0 (x4) NVMe 1.3 SSD,3480MB/s Read,2000MB/s Write, 360k/ 440k IOPS
ORDER NOW
Corsair Force MP510 series 960GB NVMe PCIe M.2 Solid State Drive (CSSD-F960GBMP510) @ £128.99 inc VAT
960GB Corsair MP510, M.2 (2280) PCIe 3.0 (x4) NVMe 1.3 SSD,3480MB/s Read,3000MB/s Write, 610k/ 570k IOPS
Only £128.99 inc VAT.
ORDER NOW
Samsung 970 EVO Plus Polaris 500GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive @ £109.99 inc VAT
MZ-V7S500BW, 500GB Samsung 970 EVO Plus, M.2 (2280) PCIe 3.0 (x4) NVMe SSD, Phoenix, MLC V-NAND, 3500MB/s Read, 3200MB/s Write, 480k/550k
ORDER NOW
Samsung 970 EVO Plus Polaris 1TB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive @ £199.99 inc VAT
MZ-V7S1T0BW, 1TB Samsung 970 EVO Plus, M.2 (2280) PCIe 3.0 (x4) NVMe SSD, Phoenix, MLC V-NAND, 3500MB/s Read, 3300MB/s Write, 600k/550k
Only £199.99 inc VAT.
ORDER NOW
PowerColor Radeon RX VEGA 64 8GB HBM2 PCI-Express Graphics Card - Stand Alone @ £299.99 inc VAT
AXRX VEGA 64 8GBHBM2-3DH, Stand Alone, Core Clock: 1247MHz, Boost Clock: 1546MHz, Memory: 8192MB 945MHz HBM2, Stream Processors: 4096, DirectX 12 Support, Vulkan Support, GCN, 1 Year Warranty
ORDER NOW
PowerColor Radeon RX VEGA 56 Red Dragon 8GB HBM2 PCI-Express Graphics Card @ £259.99 inc VAT
AXRX VEGA 56 8GBHBM2-2D2HD/OC, Core Clock: 1177MHz, Boost Clock: 1478MHz, Memory: 8192MB 800MHz HBM2, Stream Processors: 3584, DirectX 12 Support, Vulkan Support, GCN, 2 Year Warranty.
ORDER NOW
Sapphire Radeon RX VEGA 56 Pulse 8GB HBM2 PCI-Express Graphics Card (11276-02-40G) @ £259.99 inc VAT
11276-02-40G, Core Clock: 1208MHz, Boost Clock: 1512MHz, Memory: 8192MB 800MHz HBM2, Stream Processors: 3584, DirectX 12 Support, Vulkan Support, GCN, Freesync support, 2 Year Warranty.
ORDER NOW
Asrock Radeon RX VEGA 56 Phantom Gaming X 8GB HBM2 PCI-Express Graphics Card @ £229.99 inc VAT
PG X RADEON RX VEGA 56 8G, Core Clock: 1156MHz, Boost Clock: 1471MHz, Memory: 8192MB 800MHz HBM2, Stream Processors: 3584, DirectX 12 Support, Vulkan Support, GCN, 2 Year Warranty.
ORDER NOW
Asrock Radeon RX 570 Gaming Dual 4096MB GDDR5 PCI-Express Graphics Card @ £98.99 inc VAT
90-GA0K00-00UANF, Boost: 1293MHz, Memory: 4096MB 7028MHz GDDR5, Stream Processors: 2048, DirectX 12 Support, AMD CrossFire, AMD Eyefinity, 3 Years Warranty
ORDER NOW
A selection of many great parts, all suitable for building a power house of a machine with an 8 core 16 threaded processor for not huge money with CPU's such as 2700X and 3700X, then with 16Gb memory kits from £60, B450 mainboards for not much more money, of course those wanting to build a more performance orientated gaming machine and content machine can look at the X570 boards, 3200/3600 memory kits and say a Radeon 5700 XT which represent truly the best value for money gaming experience, or even consider the still exceptional value for money part the VEGA 56.
P.S. All the above parts are in stock!
I dont really see the benefit of the Taichi over the Aorus Elite, unless you need wifi I guess.
If I hadn't got the cheap Taichi I'd definitely save money and take the Elite over the Taichi.
I don't need Wifi at all as I recently hard wired my house. I've been considering the Auros elite but was concerned about the 16Mb bios memory compared to everyones 32Mb
