- 5 Feb 2006
can some one confirm please if I just put on the ISO file onto the USB or do I need to 'unpack' the contents onto the usb ?
As a side note, here's my current problem. PC starts turning on. If I try and get into the BIOS it is absolutely squiffed and looks like this https://imgur.com/QhZQkK9 and then turns all chinesey
Still not 100% fine but so far every time it fails to POST it works after 1 or 2 resets. Definitely not ideal but usable for now.
It's a no from me.Some eager person has dug up what seems to be an unreleased new B450 Carbon beta BIOS from the MSI FTP server:
https://www.reddit.com/r/MSI_Gaming/comments/chl1d3/msi_b450_gaming_pro_carbon_ac_new_bios_v18/
Use it at your own risk!
Totally understandable.It's a no from me.
Thanks for the link though I stopped using beta bios' years ago.Some eager person has dug up what seems to be an unreleased new B450 Carbon beta BIOS from the MSI FTP server:
I'll wait till it gets an official release.You used the not yet released beta BIOS from the MSI FTP page?Just an update. I used a monitor as well as reflashing and it worked perfectly, so thank you for that
The only thing connected when you do the flashback is the power connectors, nothing else.I have a different mobo (b450m mortar) I have no components connected just CPU when I do the flash the led strip at the back
Lol, anything really is possible.Well given yesterdays adventure helping someone I though was pretty good with computers out, I guess anything is possible.
Brand new 3700X, brand new B450 Tomahawk, says he can't figure out what is wrong and why the system isn't working. So I got him to show me step-by-step what he was doing, and it seemed fine, nothing installed on the board, just the 8-pin and 24-power plugged in and even did it on the the bench rather than in a case. Add's components after the flashing and nothing, just red a light.
So I asked him which BIOS he was using, he got his laptop and pulled up the file, it was also correct. Grabbed the USB stick plugged that in, file was named MSI.ROM, so that was good. I said just for good measure re-download the file, format the USB drive and try again, as he was doing that he copied the file to the USB stick then wen to re-name it, but he DIDN'T EXTRACT it from the .zip container.
I didn't know whether to laugh or cry after he told me he this was how he had tried it several times. Such a simple silly mistake as he was too busy looking forward to a new system rather than read the instructions that he though he knew. As always RTFM what a plank.
Oh yeah, it worked fine once he'd done it properly, no issues with re-boots or cold boots and he now owes me several rounds at the pub. Ha.![]()
Useful post.but he DIDN'T EXTRACT it from the .zip container.
As always RTFM what a plank.![]()
It's errors like this that are muddying the waters of the true scope of the problem of the B450.
@Journey - have you had ANY boards fail on you using these boards? I've helped 2 friends of friends over discord both initially had problems and my friends kindly :/ offered my services. Both were easily fixed, and both most user error - although the trying of a smaller USB stick was lack of experience. And in each case if i could would have reached through the ether and smacked them round the head with their eventual working board, i would have!
Great anecdote and symptomatic of a fair few 'moaners', like you say....but he DIDN'T EXTRACT it from the .zip container....
