YeahAnyone used Fusso soft 99 Paste wax? I am seriously looking at getting some once i run out of my current wax.
A bit of Gtechniq C4 on that trim and it'll look perfectThat's about all I'm going to do on an 18 year old car. That said, only 66k on the clock, so not too shabby. Was a London car originally, so actually not much rust. Even doing the brakes was fine, everything came off without too much issue. I'd imagine that was only ever done once before with these miles.
Just a shame after all that work, the silver colour means you see nothing. At least it feels smooth.
No but I really like Fusso F7 so fast easy and to apply.Anyone used Fusso soft 99 Paste wax? I am seriously looking at getting some once i run out of my current wax.
Yeah
Pros :
Beadings like nothing else
Lasts for months
Get a lot in a tin for the money
Cons:
Doesn't smell nice, very chemical smell but that's fine with me
Applying can be difficult if you apply it thick. So work with little product and apply in thin layers then buffoff will be easy
Lid doesn't like staying on the box
Overall a great wax for protection but not the best for slickness/gloss
If it's anything like F7 you need to put it on as thinly as possible.Sounds like a acceptable compromise, I have heard that it can be very hard to buff off if left to long, 5 mins max.
I got everything out ready to clean the car this morning and it's raining. Cleaning it tomorrow even if it's raining. Only needs a shampoo and rinse.
Yes. Seems to last really well, only other product I fancy trying is Poorboy's EX-.Same here need to just give my wife’s car a once over, I gave it a polish and wax a few weeks ago. So you like the f7?
That's why thin application is key with this wax. It goes a long way!Sounds like a acceptable compromise, I have heard that it can be very hard to buff off if left to long, 5 mins max.
A bit of Gtechniq C4 on that trim and it'll look perfect![]()
Any time you touch the paint work irrespective of what products you are using it's degrading the surface even a microfiber towel, that's why rinsing with deionised water and air drying is the best option.
is carrying buckets out - out ? there were some decent buckets, also with guards, pictured a while backBeen trying my hand at waterless washing this week. Living in a flat with no proper water supply means it's difficult
that stuff seems to be priced like gold dust .. I've used some german sonax which seems to bond well at a fraction of the price applied with a tooth brush on mottled dash/exteriorA bit of Gtechniq C4 on that trim and it'll look perfect
... waiting for my current ones to (inconveniently) break
