ASROCK X570 TAICHI - THE RYZEN 3000 MOTHERBOARD GIBBO & 8 PACK RECOMMENDS
22 Nov 2009
Under the hot sun.
Guys, has anyone found what the VDDG is named as on the Taichi?
Update... Found it
Advanced\AMD overclocking\Accept\VDDG Voltage Control.
Auto is set to 700mv (0.7v)
3 Feb 2010
Mine wasn't overheating as such but was hotter than I would have liked at 85C chipset temperatures with accompanying full-tilt fan noise when gaming. I found that the chipset heatsink wasn't screwed down properly on my board - there are 2 screws on the back of the board holding the heatsink in place, I tightened those up and haven't seen it go above 65C since then, fan is now inaudible over my other fans. Not sure how common the issue is but I know of a few other people who found the same problem with loosely attached heatsink.
28 Nov 2014
North East
Claims of graphics cards in the top slot blowing hot air directly into the chipset causing it to reach shutdown temps.
I use this board with 3900X and Vega 64 Nitro. No issues for me based on this rumour that was going around. I think it was probably an isolated case for a user(s).
19 Apr 2012
Possibly, there are YouTube videos where they tested it out and couldn't replicate the problem. It could be due to the heatsink requiring screwed down more as mentioned by another member here.
