- 21 Jul 2005
- Officially least sunny location -Ronskistats
He said the card though so taking it out and blowing or compressed air will shift a lot of dust..
Sounds like coil whine. What power supply do you have? My Pulse does not produce any whine.
My previous R9 390X whined horrendously when I first got it, but the problem was not the card, it was my power supply. While it was a known brand (Antec), and was suitably above the maximum possible current draw for the system, it was only 80+ Bronze rated and probably wasn't providing the cleanest power which was causing the whine. Upgrading to a Corsair HX850i (80+ platinum) solved the issue - I'm still using that power supply.
I haven't tried. So far I haven't used canned air - I do have a air compressor for an airbrush - can I use that to try and blow the dust out? Also so far I haven't tried taking the case off. Presumably there are some small screws somewhere.What makes you think you cant get the dust out of it?
I seem to remembering reading OcUK terms that they recommend a good quality PSU (like a gold seasonic, superflower, EVGA) with regards to coil whine.I hope it's not the PSU as I only just bought it! It was powering a Sapphire R9 380X Nitro until recently and that card was completely silent. It's a Gigabyte B700 - https://www.overclockers.co.uk/gigabyte-b700h-80-bronze-700w-modular-power-supply-ca-039-gi.html
I'm guessing OCUK will test the card and send it back with a delivery charge if it's not faulty? At least I'll know what to look in to though, cheers
How old is your PSU (you say its new?). I had a kolink 600w bronze that's only lasted 3.5yrs before starting to have boot problems with an OC FX 8 core (recently buying a gold 750W EVGA has solved the booting issue when the OC profile was employed).
That'll be a question for OCUK's team, I don't know what their process is for this.
In my experience 80+ Bronze PSU's are more likely to produce coil whine than higher tiers with high power draw cards like Vega.
How long ago is "just bought it"? Just wondering if a return is possible. Its not too much more to get a decent 80+ Gold or higher in the 700W range. Sticking to Gigabyte for example - https://www.overclockers.co.uk/giga...plus-gold-modular-power-supply-ca-03c-gi.html
This tier list on LTT forums is a good starting point too - https://linustechtips.com/main/topic/1045610-new-psu-tier-list/
Anything from A+ or A should not give you coil whine if it is indeed a PSU issue, not a graphics card issue.
I'm the new owner of one of these, Sapphire Pulse Vega 56 cards.
I went for a 750W Seasonic Focus Plus Gold PSU. Things seem relatively quiet to me, certainly no buzzing noises.
Can't seem to figure out the best way to benchmark the card, what software do you guys prefer?
I upgraded my not-so-good PSU to a better one and got rid of the horrible coil whine. But I asked the local shop if I'd be able to return or swap for yet another if it didn't work. Didn't come to that but it's good to have assurance.
I've been reading lots about people solving coil whine with a different PSU ever since my new Vega 56 noisily came in to my life so decided I'm going to wait on using the RMA. Ordered a Seasonic Snow Silent 750W Platinum from OcUK that's getting delivered Tuesday and I'm hoping that'll do the trick.
Thinking of buying one these can't be arsed to wait to RX5700 would 650w PSU be enough to power this and Ryzen 5 3600?
Nice might get one then.. but i have heard mixed things about the cards? some say they can get really noisy some say their fine? I usually go with sapphire but the powercolour card has 3 fans seems like might offer better cooling? any thing i should look out for? which card might have Samsung memory?
