Both are ONVIF compliant so your Hik NVR will work fineJust had a quick search for them but cant see them on there, would rather keep my hikvision nvr if possible, and not bothered about the high resolution if the image quality is good
Domes are already here, believe I posted a photo in this thread of oneDH IPC-HDW4233C-A
https://s.click.aliexpress.com/e/cWa6NH5A
£40 each after discounts.
If you really want the best night image then the new colour Starlights are superb.
https://us.dahuasecurity.com/product/2mp-full-color-3-6mm-epoe-bullet/
Only available as a bullet at the moment in the UK but the domes and turrets should be here by the end of September.
Dahua TrueColour Dome:
Not a great deal of ambient lighting, it stays in colour all night long too. I think there isn’t only one halogen light on during the entire night.
Domes are already here, believe I posted a photo in this thread of one![]()
Couldn't comment as I purchase through trade only distributor, if you're an installer I'd be happy to put you in touch.Ooh! Which distributor? The two I use don’t have anything at the moment.
That's weird, Oprema is our primary reseller. Surprised they don't have any stock at the moment if I'm honest when I'm back at my desk tomorrow I'll dig out a part code if it'll help?Yes, I’m trade. I use Oprema and Security Dynamics and neither have stock of those domes.
Just noticed you are NN4 are you an installer of cctv for domestic homes? I’m NN2 so I might give you a call for a quote when I’m ready if you do...That's weird, Oprema is our primary reseller. Surprised they don't have any stock at the moment if I'm honest when I'm back at my desk tomorrow I'll dig out a part code if it'll help?
How do you find security dynamics? They cold call our offices a lot but they look a little urrr small. Maybe Oprema and their kit has me dazzled.
Everyone has the parts codes listed but no-one actually has any physical stock. I spoke to them at the security fair in Manchester about 3 weeks ago and they reckoned September-ish. I’m happy to wait.
There is a difference between what I would recommend on here and what I have to supply to my customers to get support, keep my certifications etc.
As for SD, they were the first people to let me buy UK stock and sorted out a lot of training for me. They push HDCVI a lot because that’s where a lot of their background is, plus Dahua want to keep HDCVI alive but generally I find them fine to deal with. I’d rather just deal directly with Dahua to be honest.
As far as I'm aware, all Synology NAS devices come with two Surveillance Station licences so that takes care of the NAS/NVR aspect of the problem if you're only having two cameras.
For cameras, you want something that fits in with your house finish and how you want to position them.
Field of View is a good starting point - 90 degrees obviously gives you a 50% view of the front of your property and the idea is to get the angle so you can see the face of anyone approaching. I'm a Dahua fan and my go-to option is always a 2MP Starlight as these don't need illumination from an IR source to function. If you are getting IR make sure you get a decent range, some of them are only rated for 10m while 20-30m gives you really strong foreground illumination. The main issue with IR is reflections on number plates which tends to make unreadable at night. There is a link in post 2150 for a decent camera that won't break the bank and is compatible with Synology Surveillance Station. In your scenario I would go with the 2.8mm lens at the rear and the 3.6mm lens at the front. I would also buy the Dahua mounting bracket that holds the camera horizontal, gives a good stable platform and a bit of space to loop away any excess cable.
I actually did an install at a property like yours using the Dahua IPD-HDBW4231F-E2 'Dolly Parton' camera. I ordered one camera with the 2.8mm lenses and one with the 3.6mm lenses and then I swapped one of each on each camera. One camera 'set' at the front of the house with the 2.8mm camera covering the whole front of the house and teh 3.6mm doing just the front door and gate. I did the same thing at the rear with the 2.8mm rotated to do the whole length of the garden and teh shed at the bottom and teh 3.6mm covering the garden gate. It worked really well with a Synology NVR-218 which has 4 Surveillance Station licences as standard. To do it on your system you'd need 2 more licences which are as expensive as a basic camera (about £50 each).
https://ipcamtalk.com/threads/review-dahua-ipc-hdbw4231f-e2-m-dual-starlight-cam.28860/
Hikvision also make excellent cameras and I'm sure you'd also be very happy with something from their range. I just don't have experience to suggest anything.
Mounting is always interesting and there is a huge amount of personal preference. Some people like bullet cameras but I find they are very prone to birds perching on them and also spiders love the warmth and the light, so they get busy straight away with the web building. Turret cameras are very popular because they avoid the birds issue but they still suffer a little bit from spiders. Dome cameras are completely immune to birds and spiders but if they are mounted badly they can suffer from raindrops and if you don't leave the little bag of silica in there they can also get foggy inside if they are poorly sealed when you refit the cover.
