- 6 Jan 2013
- Rollergirl
Are you running AGESA 1.0.0.3AB?
No, unfortunately the latest BIOS is with AGESA 1.0.0.2.
I need to wait for a BIOS update then?
@Rossi~ my maximum temperature is below 70°C. The chip never goes above 4316 no matter what the load, and actually sits there all core boost to that level even on idle.
Then I would put that down to your BIOS doing whacky things tbh.
I assume you latest chipset drivers and using the AMD Ryzen power plan?
Why didn't I get that with latest drivers.? I only got Ryzen balanced but no Ryzen high performance....Yes, latest chipset drivers and set to Ryzen "High Performance" power plan.
Yeah in ryzen master I've never seen it go that high..@z10m I am using Ryzen Master to track the stats as I think hwinfo etc. are still needing updates for accuracy.
I'm disappointed that the chip can't hit the advertised boost frequency TBH, I don't see why AMD are getting a pass with this.
What LLC settings did you use and was that 1.275v under load.? What did you use to monitor voltage.?I had a quick go at an all core OC using Ryzen Master... completed several Cinebench 2.0 runs at 4300 and only 1.275v... temps a good 10-15c lower than running default settings, but then when i ran The Division 2 it would not let me tab out of game and then launch another other app but the game ran ok.. i see some of you saying your up over 1.325v which is beyond the recommended constant voltage im seeing posted on other sites, so what is "Safe" for an all core OC.. tried 1.325v but could not get anything over 4300 to hold stable. Im using a Corsair H100I Pro and have plenty of case cooling with 2x 200mm and 2x 120mm intake fans, front side and bottom of the case.
I did not touch any settings other than Ryzen Master, so used Profile One, selected cores and linked all and set to 4300, then included voltage and set it to 1.275, hit apply and then ran Cinebench a few times, score went up from 4751 to 4951 for multi core test, but single core dropped from 509 to 478. voltage was monitored in ryzen master and HWInfo.
Highest boost that hwinfo64 recorded was 4.375 but usually when gaming it's boosting to 4.225-4.2275.
That's on the latest MSI bios with AGESA 1.0.0.3AB.
Does anyone have a link to a decent guide, i cant find anything clear as there is so much speculation on bios issues and versions etc.. max safe voltage... ?
BIOS and AGESA are hit and miss currently. As for the max safe voltages, anything other than stock is just pure speculation as to what's safe and what's not. Even The Stilt had a chip degrade rather swiftly, though he did say that it'd seen TjMax a few times.
