Tamzzy's back to air-cooling ITX build
frankensteined :/
no cooler currently lol
thoughts on the case:
1) FEELS CHEAP :(
2) little rough around the edges...eg wtf the front usb port cables and power cables are faaaaaaar too long...its a small case, not a friggin ATX sized case
3) had to mod (and remove the middle bracket at the front to get the cables in - i bought the non-ARGB version for £80. the ARGB version is £12 dearer...wouldn't have been able to use it unless one had short cable mods and probably a sfx power supply.
tl;dr - don't get the ARGB version, waste of money
*Will you be admitting that you activating the RGB on the case?
nope, not connected lol :P
Although, once grafted together, the build should be considerably sturdy (thinking of internal assembly/design). And, once it's built/working and the 'RGB is cycling through its repertoire of preeedy colours' - you'll forget about the adaptors/quality on the inside.
yeah it's a once built then leave it the **** alone lol
but i'll have to dismantle it again - need a proper HSF instead of the H100i and also waiting for my 2nd MP510 to turn up.
so still WIP.
I haven't properly cable managed because of this...but if it fits now, it'll fit when I finish the build properly
LOL - i can certainly see the appeal in these compact cases - so unobtrusive with add-ons.
No go with the 2.5mm fan?
it'll fit.
cryorig c1 on order.
imma try it with my gentle typhoon first and see what the temps are like. if too warm then i'd get the noctua NF A-15 (140mm fan with 120mm mount)
Maybe they didn't want to leave any space unused?
lol maybe :P
Mmm. How easy is it to cut though ...
the actual case itself is the same, just the fascia is different 0 rvz = plastic, ftz = alu
if you're cutting into the fascia then it's gonna look fugly
there's also not a lot of room past the actual case itself
and definitely cannot mount a 3 slot gpu because of the power connector - unless you unscrew it and leave it hanging out because the M-F connector is in the way
@tamzzy - excellent - now make that chunk of metal sweat!
With direct venting can't see temps being an issue - ambient case temps may be interesting.
build cost (also updated the top post)
Ryzen 3700x £300
Aorus X570I PRO WIFI £227
2x 16gb Crucial Ballistix LT e-die £146
2x Corsair MP510 960GB £190 total - from MM
EVGA 1080ti SC black edition £570 (reused)
Silverstone RVZ03 £80
Seasonic Focus+ Gold 650w £60 (reused)
Cryorig C1 (with Gentle Typhoon fan) £53 (+ £10 for fan reused)
Total damage build cost: £1636
New(ish) items: £996
