- 19 May 2005
Had a play with one in cpw, changed from simfree Samsung order to contract due to work discount making it cheaper.
Some models have moved to 3rd sep from cpw I noticed yesterday
Not sure what case to go with. Been using Spigen cases for years now, always very impressed with them. Anything else I should be looking at?
Did you receive the protective standing cover yet, seems to be out of stock everywhere, managed to get mine from mobilefun, it's being delivered tomorrow.Ive gone for Samsung Led case and Samsung's protective stand case in silver
Worth it?
Only you can answer that, depends if £290 is a lot to you...I'd personally say no, I'm upgrading, but I have a s7 Edge...from 10plus to a Note 10 you're getting slightly more power / RAM but not sure you'll even notice that in every day use, slightly bigger screen...very minimum gains, obviously you'll get the stylus but as you don't have a Note currently I guess that's not a must have...I'd hold out and see what the 11 or even 12 have...Is it worth changing from a s10+ to a note 10+?
An additional cost of £290 to upgrade and an additional cost of 10 per month for the same unlimited contract.
Worth it?
