personally, i would. seeing as you have a large enough budget@tamzzy just reading the thread you linked to is it worth getting 32gb of memory off the bat then you think?
tl;dr version - depends on how you balance your budget
While RAM can be easily increased later, memory is now well priced after many years of insane pricing courtesy of DRAM maker cartel.@tamzzy just reading the thread you linked to is it worth getting 32gb of memory off the bat then you think?
That immersion is just cut down by lacking image height in stereo vision field of view.I really think it's worth squeezing in an Ultrawide monitor when you are on this sort of budget, it is the only thing you can's upgrade or change once you've committed, and it makes playing games way more immersive due to the peripheral nature of our vision.
Have to be quick with these parts dont you? They're all out of stock now![]()
Meh, is everywhere it if stock of everything? Or do you just mean OCUK?
Mainly on OCUK but quite a few of the parts are out of stock on other websites as well.
There is certainly a great deal of demand around presently, best bet is to AHHHHHHHHHHHHHHHHHHHHHfffffffffffffffffeeeeeeeeeeeeeeeeeeejjjjjjjjjEEEEEEEEEEEEEEEEEEEEEE or put things on back order here. Be warned however OCUK do charge up front so even if you wait two months you'll have paid in full, I know some other places do this as well it is best to check first.![]()
^^^^^^^^ POWER!!
surprised @Plec didnt do the master board... hahaha
would do Dark rock 4
maybe phanteks - seems actually Fractal mesh designs aren't as freeflowing as Phanteks. Gamers Nexus showed Phanteks P600 beating it
https://www.overclockers.co.uk/phanteks-eclipse-p400-air-midi-tower-drgb-case-black-ca-09g-pt.html
Like that case wise wasn't 100% anyway!![]()
sorry added to post with PSU![]()
Yep, you would still have the aesthetic and save a few poundswould do Dark rock 4
You could drop to 650WThis one?although it appears to be £20 so maybe I've found the wrong one?
https://www.overclockers.co.uk/cors...lar-power-supply-cp-9020179-uk-ca-23w-cs.html
