**THE OFFICIAL AMD CHIPSET DRIVERS THREAD**
18 May 2010
London
I thought I'd create an OFFICIAL AMD chipset drivers thread as a satire of the AMD and Nvidia GPU driver threads. :p
You can find the drivers found here.
There was an updated set of drivers pushed yesterday. They seem to be a fairly minor update but you can find a reddit discussion here on what was updated. New power plan apparently.
Lost 200 points on my Cinebench and my temps have gone up loads since installing yesterday’s new chipset drivers :(
LOL! Some happy people in that Reddit thread. I'll stick with the current BIOS and drivers until this **** show settles.
Looks like AMD are on it though and have got together to discuss the post-launch "niggles":
These chipset drivers have worked well for me. Has helped with the issue I was having with the cores boosting up to full speed even doing simple basic things on the desktop. And, unlike Steedie, my temps have dropped but the performance has improved.
Anybody had an issue with the pc turning itself back on after a shutdown?
It doesn’t do it all the time but when it plays up I can turn it off 3-4 times in a row and it’ll turn itself back on. Sometimes I have to shut it down and turn off the psu via its switch.
No, but I have an issue where a restart from W10 actually does a full power cycle instead (shutdown fully and power on).
can anyone confirm what the minimum processor state in ryzen balanced is set at on these drivers? mine is 99%
I use Windows High Perf with 1% minimum since got the 3900X. Finding it has the most sustained boost clocks, (4.4 on 12 core, 4.6 on 6 core configuration) with the CPU idling most of the time at 0.95v
So is Ryzen balanced plan actually recommended/usable these days? Used to be horrendous, at least on my 2600, idle temps in the 50 range.
