semi professional streamer so the performance is additionally quite important.
I'd just use NVENC to stream.12 cores and x570 ultra to keep costs down or even the
semi pro streamer.... would have just gone 1440p 165hz and 2080ti !
12 cores and x570 ultra to keep costs down or even the Pro
heck, 9900k overclocked to 5ghz !
3:50 in
if your looking to claw max FPS for ourself as well as high quality stream for viewer
if you record and then edit, ryzen 12 core gets the nudge ahead and a few fps lost
I'm a live-streamer, record and editing is more for my other career I do, however I am interested in recording and editing game footage as well. Apologies if I should have made this clearer, I did mention it in the original post but only just realised that it kind-of fell to the way-side. Also probably explains the higher budget![]()
sorry, added another video to the first post- more detailed break down of nvidia vs amd vs intel
now its your bread a butter almost- you dodge the £££ bashing , as like you've seen , we'll try and spec with a sane mind... your a streamer.. sane is out the window !
looks like 3900x may do it all, but seem 2080ti could do it better- and dropping to 3700x and 2080ti ! POWER!
My basket at overclockers uk:
- 1 x Gigabyte X570 AORUS MASTER (AMD AM4) DDR4 X570 Chipset ATX Motherboard= £389.99
- 1 x Corsair Force MP510 series 960GB NVMe PCIe M.2 Solid State Drive (CSSD-F960GBMP510)= £149.99
- 1 x Corsair Vengeance RGB PRO Black 16GB 3600 MHz AMD Ryzen Tuned DDR4 Memory Kit= £128.99
- 1 x Corsair RM Series RM750 750W '80 Plus Gold' Modular Power Supply (CP-9020195-UK)= £99.95
- 1 x Phanteks Eclipse P400 Air Midi Tower DRGB Case - Black= £83.99
- 1 x Gigabyte GeForce RTX 2080 Ti Gaming OC 11264MB GDDR6 PCI-Express Graphics Card= £1,169.99
- 1 x AMD Ryzen 9 3900X Twelve Core 4.6GHz (Socket AM4) Processor - Retail= £529.99
I've amended this build slightly to be an 850W PSU, the Ballistix RAM, 2TB SSD and the P600S Silent Tower bringing me to £2796.04.
pretty damn good if you have a rtx 2000 series gpu.I'm not sure how NVENC holds up from the YouTube videos.
personally would use a 3700x and 2080 and use nvenc to stream.
don't really need uber uber hardware to stream. just needs to be smooth and stable (but you already knew that)
well, you're basically building the porsche equivalent of a pc...so i should certainly hope sobut does it work?
well, you're basically building the porsche equivalent of a pc...so i should certainly hope so![]()
