Coil whine can happen to any card.coil whine
I'd rather get the faster card that I can downclock for noise/temps than a slower card that I can't oc with lol
The louder fans/coil whine won't be an issue? I had the Zotac in the basket originally but the better reviews for the Gigabyte made me change over. Happy to change back though if the Zotac is overall better - i'd just rather a slightly slightly slower card that lasts well past the 3 year mark than a faster one that doesn't![]()
Wow now that build looks beastly.LOL My EXACT reaction. But I don't mind because it was an excellent discussion to read and learn from, and a result of you lads putting in sincere effort in my behalf. I'll re-read and reply to all the monitor stuff later once the system is ordered.
So based on your facts being correct, especially bolded ^, this was an extremely convincing argument. @tamzzy said before when I asked him that upgrading the CPU is very easy nowadays because AIOs aren't a pain to to disconnect. My ONE concern with the 3600 is certain threads i've seen, THIS being the latest one where it appears to have some issues with the MSI Tomahawk MAX motherboard. But hopefully those are just rare problems and OcUK will snuff those out during the build, and they wont magically crop up again after the 3 year warranty has expired.
Current build:
My basket at Overclockers UK:
- 1 x NZXT H500 Midi Tower Gaming Case - White Window= £69.95
- 1 x MSI B450 TOMAHAWK MAX (Socket AM4) DDR4 ATX Motherboard= £106.99
- 1 x NZXT Kraken X62 AIO Water Cooling Unit - 280mm= £139.99
- 1 x AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail= £188.99
- 1 x Gigabyte GeForce RTX 2080 Gaming OC 8192MB GDDR6 PCI-Express Graphics Card= £629.99
- 1 x Corsair Vengeance RGB Pro 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit= £119.99
- 1 x Gigabyte UD Pro 512GB SSD 2.5" SATA 6Gbps Toshiba 3D NAND Solid State Drive= £59.99
- 1 x Seagate 2TB BarraCuda 7200RPM 256MB Cache Internal Hard Drive (ST2000DM008)= £55.99
- 1 x Seasonic Focus Plus 650W 80 Plus Gold Modular Power Supply= £94.99
- 1 x CableMod PRO ModMesh Cable Extension Kit - White= £44.99
- 1 x NZXT Aer RGB 2 Fan with HUE 2 Controller - 120mm Dual Fan Pack= £71.99
Went with the Gigabyte (4 yr warranty) over the Zotac (5 yrs) because reading elsewhere I found loads of report that the Zotac sounds like a jet engine compared to the Gigabyte.
Do we have a consensus? @tamzzy @Plec @orbitalwalsh @aoaaron![]()
2x 32" 1440p screens (you know this)
when my 2nd stick of 16gb ram comes back...i'll try running 2 games simultaneously...LOL
That's impressive. What memory chips did they have?
Was that a stroke of luck or you already had some insight that it was likely to be B-die?Just had a look before I packed it up, it appears to be K4A8G085WB-BCRC which is a B-die chip although not one I've come across. It was unbranded RAM, so I'm happy with that and I might buy more to see if it the same.
It was bought blind through a place I work for sometimes, it was the cheapest I could find that I could get quickly. So pure luck.
Sorry OP, didn't mean to off-topic your build thread.
snap up as B-die has stoppedMy fault too. Apologies OP.Sorry OP, didn't mean to off-topic your build thread.
Best value for money processor with one of the most powerful consumer grade gpus money can buy.
I’d just get the card with the best warranty which is easily accessible. Google the companies name and see how easy it is to locate an email in the uk. If it’s hard, don’t bother with them.
Zotac are a bit naff.
classical case of sampling bias, isn't it.Chaps have you seen this thread?
Chaps have you seen this thread? Slightly worrying, had a look online and there appears to be a number of people reporting issues with the B450 Tomahawk Max.
if ocuk build it for you, aren't you covered on warranty if something fails or starts playing up?
Great - what was the final build spec?
Did you haggle?
nice, let the thread know how you get on![]()
