Tbh man it sounds like you don't really want it at all, might be better to source a more sensible alternative![]()
I also think you need to know what kinda games you want to play on that.
and the FOV looks amazing for sim racing (which is probably 70% of my game time).
? Any advice? its on the periphery of the screen, onyl can see it on a white background.
I'd say it was fine tbh as it's on the edge of the screen, a replacement might have one bang in the middle!!
Alienware is a *tank* !!
Let us know when your sending your dead pixel one back so I can pick it up as a B Stock item with a big discount![]()
The new Mortal Kombat will blow you away on it.
If you like fighting games - The new Mortal Kombat will blow you away on it.
Its like a better arcade experience then the actual arcade experience. If I had a shop I would set it up for £1 for 3 Games and people would flock to play on the ultra wide
@aoaaron
How have you found the black smearing in dark scenes? Do you even notice it?
Can you change the overdrive settings while freesync is on? (I had heard you couldn't, hoped it had been updated through firmware).
However I feel my current GTX 970 will not cut it.
@aoaaron
What version of displayport do I need to get to the full resolution and refresh rate?
