I will need to upgrade just for that then as my 970 only has Displayport 1.2.DP 1.4
Hi,
I've currently got the itch to upgrade and I'm looking at this on a certain site as they have a few in stock all of a sudden but I don't know if its right for me.
I do love my games like BFV, Overwatch and occasionally Total War I'm not competitive anymore just with getting older and reaction times have slowed but I do like to play to a good level, I'm worried that my 2080ti won't be able to give me a good fps on the full rez, do you think would I struggle ?
Productivity wise it would be good as I often have multiple PC's and or laptops on the go at the same time for work so being able to put them into the same monitor might be good.
I currently have the Alienware AW3418DW and I'm not sure if it's worth the upgrade or just the itch to upgrade to HDR.
Any advice would be greatly appreciated.
Thanks.
Hi,
Thanks.
Thanks gents for the input.
I currently have an OLED (well curry’s have it in for screen burn at the moment even though it’s on eco and and screen shift is on ) and I thought the HDR would be just as good for some reason.
I might look at the upgrade as a pure real estate gain then.
I would love to see one up close but unfortunately that’s not possible, asi can’t imagine anywhere stocking these on there shop floors.
Third times a charm.
Just got this monitor the other day. It's stunning apart from the black smearing on dark backgrounds. It's looks as bad as by old ultrawide IPS backlight bleed and is most noticeable on dark loading screens.
I was wondering if there is some screen settings I can change to try and reduce it?
