- 17 Sep 2018
So i have a question. Is it normal for a vega 56 not to run at max clock all the time in all games, as for example i was just having a quick go in borderlands 2 and at max settings at 1440p im getting max fps with no vsync (freesync) tho i have limiter ingame at 72 and i get 72 always. But msi afterburner osd shows the games using about 800mhz core and 700 and not 800 on the vram and sometimes 500hz yet i still get great fps. Temps are about 44c, the gpu and cpu are barely used like max 50% for any of em usually lower like 30%.
Just find it strange a game can run that good with so little usage from gpu and actually cpu as well at 1440p maxed. I could probably run it 4k and still might not get the cpu or gpu up much more lol.
Also notice gpu not maxing as well in a few other games. Tho some games it can get high usage then put the clock up. Seems like when i had a nvidia card it usually went max clock regardless of gpu load most of the time unless im remembering wrong.
Is it because of undervolting and underclocking slightly from default 1590 to 1552 as stage 7. Tho i think ive seen gpu get to 1600+ before regardless of what i set it at tbh.
Vega throttles and struggle to maintain clocks, I think that's why you undervolt because it clocks nearer 1600 when undervolted. Flashing to a Vega 64 or using power play tables can help it clock higher if you need extra grunt now or down the line. If you use power play tables you can hit 2070 levels of performance
Because of this it can actually perform worse if overclocking
