Is there any real difference between the Sport LT and Sport AT sets of RAM?
My understanding is it's just an Asus TUF themed heatspreader with the colour matching that of their motherboards.
YMMVi bought 2 x 8GB of these. should these not overclock better than 2 x 16GB?
Mine was a quick and dirty overclock - I care more about playing games than getting 110% from my hardware. With that disclaimer out of the way...
1) enable xmp/docp
2) set soc voltage to 1.1v
3) set memory voltage to 1.4v
4) set vtt to 0.7v
5) set memory multi to 36x
6) set infinity fabric to 1800
7) profit???
I left everything else at auto
 Excatly what I have been looking for, as I'm not aiming for the "max" oc.
 Excatly what I have been looking for, as I'm not aiming for the "max" oc.Let us know how you get on. I too am not looking for the bleeding edge from my machine, Just a nice improvement will be dandy.Thank you! I will try Tamzzys settings firstExcatly what I have been looking for, as I'm not aiming for the "max" oc.
That's me all setup with drivers etc now.
Ive only been in the bios once but sure I noticed my ram sitting at 2400mhz is this just the default it will sit at until I actually set stuff?
Yep that's normal but you can enable xmp temporarily to get more out of the ram.
Ah ok, Perfect thanks. I've noticed in Ryzen master it shows the infinity fabric and memory clock as 1200. I gather because that they are synched correctly?
