Caporegime
- 21 Jun 2006
DH IPC-HDW4233C-A
https://s.click.aliexpress.com/e/cWa6NH5A
£40 each after discounts.
If you really want the best night image then the new colour Starlights are superb.
https://us.dahuasecurity.com/product/2mp-full-color-3-6mm-epoe-bullet/
Only available as a bullet at the moment in the UK but the domes and turrets should be here by the end of September.
https://www.aliexpress.com/item/32832960951.html?spm=2114.12010610.8148356.2.53dd736dne49XP
https://www.aliexpress.com/item/32580229073.html?spm=2114.12010610.8148356.8.53dd736dne49XP
are both of these not better than the 2mp option?
appreciate some help as I'm looking to buy ASAP.
Also what would be the best NVR?
And best way to mount them to a wall? I can't mount them under a roof will need to attach to wall so would I need the junction box or the wall mount?
https://www.aliexpress.com/item/32324940864.html
or this
https://www.aliexpress.com/item/32815045525.html?spm=a2g0o.cart.0.0.1ecb3c006jPxVX&mp=1
if you click on this link
https://www.cctvaware.com/blog/correct-installation-height
that is how I will be installing them to a wall rather than under the overlap of the roof. so 2.6m high for back garden and 5.2m high at front of property.
so do you advise then 6mm for front for zoom? or 3.6mm for wider angles?
back garden i'm thinking 2.8mm because it will be low down so no need for zoom.
thanks for help in advance. i would like the best NVR with smart features. I want to be able to watch cameras off mobile other side of the world, etc. possibly even ping me a notification if a person comes into a certain area too would be great.
daytime quality is really decent '4k' but you would struggle to ID a face at >10m in pitch black night IR
Afraid i've got Hikvision for my cameras and DVR so not sure how much help i'll be.
