- 13 Apr 2010
- Sunny Sussex
Whos decision was it to take to kwikfit for work? Only thing they can do is tyres and MOT lol.
It's directly opposite her work. Mini is a pita fo get to
Within the 12 months period??Wife took her 3 year old mini cooper sd for a service at mini today. The front pads kwik fit fitted last year are incorrectly fitted, have worn to basically zero and cooked the discs
Mini couldn't change them as they haven't got any discs and don't know when they will, she had to sign a waiver to take the car.
I'll be at kwik fits door first thing limbering up. It took them 4 visits to fit them as they snapped a sensor and the replacement was the wrong one.
Idiot's
This track only has 1/8th, great fun though
how did they fit the pads incorrectly? I mean it’s not like you can fit them upside down or inside out without noticing that somethings not right. Bmw sensors should be replaced not reused most of the time they snap and If they don’t they sometimes don’t let you reset on the dashWife took her 3 year old mini cooper sd for a service at mini today. The front pads kwik fit fitted last year are incorrectly fitted, have worn to basically zero and cooked the discs
Idiot's
No video msg? Anyway think they tying to scare you, it’s impossible to fit pads incorrectly without noticing. Probably didt clean the carriers.I did ask but it was the service drone.
Sorry I tried to find a pic of a mini but this came up https://m.youtube.com/watch?v=QK_tupsxboQ.Yes video shows one wheel free and the other wheel completely bound up and a close up of the pads, they say the pads are the wrong way round?
That looks like corrosion it’s common.Clip from the video showing the disc burnt on the inside
If you cooked your discs any rust on the dick will turn a reddish color
