I'm playing in a laptop, 6700HQ (4 cores, 8 threads) and a 1060 6GB. All fine at 60FPS 1080p med/high settings.
Your 8400, whilst having 2 fewer threads, is around 50% faster than my cpu in general, I doubt that is causing your woes.
Personally going to wait til it’s out on steam as by then the multitude of bugs should be squashed and it’ll be cheaper... then again you could buy it now and have no issues at all! Depends how bored you are I guess !Considering the problems, etc where is this game now?
Don't buy until they fix the major problems or it's worth getting even with the bugs?
ty
Futureman9000
To skip the opening logos each time you start the game:
-NoStartupMovies
If you are having performance issues like with frame rate or stuttering you can add:
-high -USEALLAVAILABLECORES
I seem to have got ahead of myself. I've just met Zero and am level 10 but the loot is all level 11+.
@imginy rookie question and might have been asked but have you tried running it off a different drive?
EDIT: Additionally...have you got plenty of spare space on the existing drive?
, so will wait for a less buggy game.
