Give me your Vega as a kind gesture then treat yourself to the 5700XT![]()
ill send you the box sure
They have the same requirements.
Not really
5700 180w
5700xt 225w
2060 super 175w
2070 super 215w
Figures from AMD and NVidia own websites.
Not really
5700 180w
5700xt 225w
2060 super 175w
2070 super 215w
So will I be okay with 550w for the 5700 XT?
Brilliant thank you
Is this still the case if I overclock my CPU? I wouldn't need a new PSU?
I'm really not knowledgeable on voltages haha my apologies!
Wouldn't be overclocking the card, only thinking about the CPU (2700)
Brilliant thank you
Actually if you get a 5700XT you should undervolt the card not overclock it.
You gain more performance that way hitting higher clocks while burning less power and generating less heat & noise.
But do not touch the Power Limit, leave it 0%. It just adds power consumption on the Navi GPUs on air and 0 perf increase.
That from own experience as started tweaking heavily my 5700XT AE with it's stock blower cooler.
Undervolting the card heavily (1044mv) and underclocking it (down to 1980Mhz), got flat 10% increase in FPS & benchmarks performance. Which also reduced power & heat in the process considerably.
Nvidia own's website recommends 550W PSU, and 5700XT 600W PSU. Hardly any difference.
It's very weird why AMD doesn't implement some intelligent way to follow such cases. Because obviously not all of the cards are able to do so.
But anyways, this is a pretty significant gain and AMD can soften the "negative press", while improving their performance graphs.
So not the same requirements then.![]()
SureThanks @Panos
I'll have to do a bit of research into that though - might come back with queries once I've bought it
Cheers!
A massive 10 Watts?!?!? How will we ever cope...Not really
5700 180w
5700xt 225w
2060 super 175w
2070 super 215w
