- 19 Jan 2019
- Co. Down, N.Ireland
Latest driver update 19.9.3 my mHz by default is set to 2004 now pretty sure It was set higher.
What version of 5700 Xt?Latest driver update 19.9.3 my mHz by default is set to 2004 now pretty sure It was set higher.
Is that the setting in WattMan?My Nitro+ hits 2045 at 1.182 stock
What’s this about buildzoid saying the nitro+ is a side grade to reference?
Thanks,He means the pcb/vrm is slightly worse than reference. What that actually means in reality is very little.
Someone posted this on reddit about Global Wattman. Anyone else noticed this video?
https://www.reddit.com/r/Amd/comments/dcz9k6/5700_xt_not_game_boosting_as_it_should_in_games/
I can also confirm this. This is a major issue that might explain why I am having issues.Yeah I sw the thread earlier.. he has updated it since with the video. I can replicate the wattman slider behaviour but my boost holds fine in the only game installed that he mentions (overwatch).
I don't use it myself as I want raw performance. Do you actually see tearing? If so freesync should be all you need. And turn on Image Sharpening (no performance hit). I notice it in game right away.Has anyone got Enhanced Sync on?? I've free sync on and don't know whether to have image sharpening on, anyone with advice be greatly appreciated. Also has any experience a micro stutter?
@Panos did you watch that video yet?
When you get a chance look at the video in the reddit post.Cheers mate will give it ago
