- 19 Jan 2019
- Co. Down, N.Ireland
Benchmark first & surprisingly WOT. Is my go to game for testing stability of GPUs. If there is a single issue just a run on Firestrike didn't found, WOT will always do.
If WOT doesn't have issues with Graphic & CPU overclock is fine. As weird as it sounds. Had overclocks looking fine on prime, etc and when WOT run system crashed.
So if the system manages 2 full games in WOT is perfectly stable.
Also by raising the middle point, found ESO a CPU bound game, giving me better performance today on many scenes especially at Elswyer expansion zone which was suffering.
True the game doesn't boost the GPU properly, because is CPU core bound. On Vega 64 has to create a custom profile for that game to use P7 state as a minimum state. And now found with the 5700XT if I have a linear line not a curve maintains better fps on CPU heavy areas.
Doubt even @LtMatt can explain this different behaviour, that by replacing the curve with straight line, get more stable perf on CPU bound games.
Okay thanks I'll try again, just test there with straight line crashed on me, should I the auto undervolt settings in Manuel then tweak round it? Also has anyone got the quiet n cool turn on in bios? I've mine on.
