- 25 Aug 2015
Depends which Raichu, the normal one can be quite easy with the correct counters as a solo, the alolan form has a few better counter options.
You'd ideally need to use some Groudon's, Rhyperiors or Rhydon's with Mudslap/Earthquake. I think I read somewhere 1 Lvl 40 Groudon can take out the Raichu without fainting, not sure if it was BS tho.
Alolan forme, you can use Tyranitar with bite/crunch or Mewtwo with Shadow ball if you have any.
Unfortunately we don't have any of those pokemon. We managed to beat a 3* raid yesterday and caught an Exeggutor at least.
Our trainer codes are; 1257 0755 4526 and 3353 2511 3977 if anyone can add us. We'll gift regularly if you're able to as well.
You'll be able to solo a machamp 3* raid if you power it up a bit.
