@Panos
I finally got BFV working again as it once did with my fury.
But it took DX12 and 19.10.1 so I don't know if it took both or just one of them.
However, everything is once again smooth as butter. I'm getting over 120 FPS in Metro map @1440 medium settings. I may go all low settings as this is the go to settings for "sweaties" (people who like to run/gun with high fps).
DX12 is a funny ip. You have to allow it to "load up" which can take a few minutes. Once it's done "doing what it needs to do" BFV becomes smooth again. But it took me a few minutes to remove the odd stuttering every once in a while. Hmm, come to think about it by the time the round ended everything was smooth as butter.
What made me stick with it was that it even though DX12 was stuttering at the beginning it was still better then DX11 stutter/Lag.
IndeedHuzzah![]()
4pm is the cut off for tomorrow delivery right?1.25 stock v?
just found this nugget of information, just when I was giving up
https://forums.overclockers.co.uk/threads/powercolor-returns-to-overclockers-uk.18571599/
3 guesses what I’m getting![]()
That’s not good I was just about to empty my current account. I’m going to hold off and see if I can find that threadhave to find a thread were staff posted up Powercolor didn't respond to RMA for replacement card within 28 days so OCUK had to give them a sapphire card instead! about 2 months ago
Can’t find it, I did find one where he under volted a Vega 7 and it died, tried to rma and told the shop he under v’d the card so he had is rma denied. He then went to PowerColor direct and got a new cardi think the owner was happy to get a Sapphire Nitro+ . might of been a once off. But believe OCUK handle RMA but still has to be cleared to hand out a new card from their stock and get one back from Powercolor
Is anyone running a 5700 XT with an OC'd 4770K? What's it like? I feel like I'm severely bottlenecked.
I thought soOfc the 4770K is bottleneck on all new games today.
I thought so
Upgrade time then, sigh
Depends if you play new current games yes unfortunately. 3700X/3800X going to help a lot, with a cheap board like the £100 MSI B450 Tomahawk Max (don't get the non max), and good ram kit 3600C16 so you can OC it to 3800C16 where all the performance is. And you can always upgrade up to 16 core CPUs for this gen and next year when you want. Z390 is dead end and obsolete already for any upgrade path.
Next year Intel CPUs need new boards and so the 2021 motherboards with DDR5.
So floor budget is £240 for both motherboard & ram (3600Mhz) and anything after that is the CPU. eg a 3700X costs £306.
Make sure you do a fresh windows installation though.
Yeah only playing the latest games.
Definitely getting the 3700X and some good RAM. A bit undecided on the board, was thinking x570? Need to research a bit more.
I thought I'd be happy with my new monitor and GPU but here I am wanting to spend more money. Oh well, it's probably worth it since there are quite a few new games coming out which I'm very interested in.
