For only gaming I would honestly just get a 3700X or 3800X. What other tasks do you do that you need 12 or 16 cores for?
X4 Foundations
Thank you, I shall look into that. I thought (perhaps mistakenly!) that 2700x could only address or use ram up to a certain speed?
This seems available for £230 any good?Have you considered 3900X and replace the RAM?
G.SKILL Ripjaws V Series 32GB (2 x 16GB) goes for around £114 (F4-3600C19D-32GVRB), is C19 but with bit power and the help of DRAM Calculator might do 3800C16, if not then 3733C16.
If you want better ram, £230 G.SKILL TridentZ Series 32GB (2 x 16GB) 3600C17 that would do 3800C16.
The options are easier and cheaper if you are find with dual stick 16GB.
With a 3900X @ €530 (~480/490) you would be set.
I know but to be fair even my old i7 7700k was. complete overkill and whipped through both LR and PS. Probably better than my new 2700k so just would like a little of that single core performance back and given am already on an eight seems silly to buy another eight core now when I enjoy building ott machines.A quick google shows that neither of those take much advantage of a great number of cores. I'd suggest researching a bit more but I would expect a twelve core 3900X to offer little over the eight cores of a 3700X for those applications.
G.SKILL 32GB KIT DDR4 3600MHz CL16 Trident RGB Neo
I shall wait till the 3950x comes out and pick up a second hand 3900x for £250!!!A 3700x is £338.99 on ocuk right now and a 3800x is £389.99
I bought my 3900x for £479.99
Best cpu I have ever owned PERIOD....and I’ve had hundreds over the years...
Good luck with that one. Maybe if you wait about 2 years.I shall wait till the 3950x comes out and pick up a second hand 3900x for £250!!!
Actually. I might buy then.Good luck with that one. Maybe if you wait about 2 years.
Cities Skylines uses 1-2 cores not 8.Blimey, I can't even use 8 cores, nothing utilities this 3700x, if Cities Skylines utilised it with all these assets it'd be running like lightning.
Try play X4 or X:R![]()
CL2 next year might doThat's what I mean IF Cities Skylines used 8 cores lol.
What’s CL2?CL2 next year might do![]()
What’s CL2?
