860 is AHCI based SATA not NVMe, all the drives I referenced were obviously NVMe PCIe. As I mentioned an online retailer who offer same day delivery and you mentioned one that fits that description, if you look at the 2TB 660p pricing from them and then compare it to any main brand 2TB TLC drive you’ll see they are roughly twice the price, I haven’t looked at OCUK’s pricing recently, but they generally tend to be slightly higher with a similar metric.
You keep focusing on the type of cache, but ignoring that it’s less important than the size of cache. If the industry moved to MLC/TLC cache, that in itself will make little difference. A QLC drive is ‘fast’ if you stay in cache for writes, so as long as you are dumping under 76GB in one go to a relatively empty 500GB drive, you get full speed, as that scales up on a 2TB drive it becomes increasingly likely you won’t fill the cache. Reads will always be fast, so choose a drive with a large enough cache for your needs and you’re not going to notice the difference outside of synthetic benchmarks or doing something silly. Non of that will help a full write scenario though, which is where you went wrong.
As far as my pricing goes, I got cheap deals at the time, at least one other person got similar pricing on a 2TB 660p here, but pricing has generally gone up in recent months as the exchange rate has gone down, the % difference is still similar.
On the contrary, the type of cache determines the size of the cache, if it was MLC you would have double the size of the cache.
Considering that the sustained write speed of the Samsung QLC flash is 80MB/s I think it's reasonable to compare against SATA drives.
When it comes to larger capacity drives, there is a somewhat bigger difference in price but not twice the price when comparing the same brands, the 2TB QVO is £210 and the EVO £270 for example. But larger drives aren't really economical when you can RAID 2x 1TB drives for less money and double the performance... I'm getting 1GB/s sustained write even on the oldé SATA interface.
