What do you think of the X-fi R3X?
Early days still, I noticed a slight 3-4 sec lag with my bios upon start up. Disconnected the X3 and the bios start up lag vanished I think though this is normal since a USB soundcard is connected am only use to internal soundcards where they don't have this slight lag.
As I was testing the bios lag issue and trying different usb ports I noticed the SB blaster command software crashed during shut down a few times, I just clicked ok on the error message to continue shutting down, I guess this is due to SB blaster software being new and buggy.
I will also have to cover the blue neon lights its somewhat distracting in the middle of the night, I would have thought creative would allow you switch off all the lights via the software.
Not any major issues really, 3-4 sec lag is liveable, soundblaster command can be disabled on start up easily and opened and used when required via the short cut icon and blue tac can cover annoying led lights easily
Otherwise its a nice bit of kit, I do wish I kept my AE5 a bit longer and did a proper comparison but the X3 is a powerful sound card.
If Creative had released an soundcard with optical input and X-fi I would have opted for that, but id bet its in the pipe line.
Did you flash the firmware and did it fix your switching off auto on shut down issue ?
