- 18 May 2010
RIS is basically a way to reduce your rendering resolution whilst keeping visual quality high. For example, instead of rendering at 2560x1440, you could render at 1920x1080 and enable RIS. It won't look as good, but it'll look better than just rendering at 1920x1080. Of course you'd then get the benefit of a higher frame rate because rendering at a lower resolution is easier for the card, and RIS has minimal impact on performance.
Chill is particularly useful for laptops or louder cards. It lets the frame rate drop when there isn't much movement on screen. Instead of rendering everything as fast as possible, it instead might see that you're not moving your character and drop the FPS from 100 to 40 FPS (random example). Your card will obviously run cooler when not working as hard.
I personally don't use either feature. I am very sensitive to image quality, particularly frame rates, so I prefer native rendering and high frame & refresh rates at all times, but they are certainly useful features for some.
Afterburner is a third-party app that allows you to change your card's voltages, clock speeds, and fan profiles. I personally only use it for a nice custom fan "curve" (really a stair step) because AMD's fan control is *****. I use AMD's own WattMann for my undervolt and overclock though since it works fine. Maybe one day I'll be able to ditch Afterburner.
Thanks for the info, none of it appears to apply to me which is what I wanted to confirm.
Sorry I didn't mean Afterburner, there is a new driver feature and I can't remember what it's called
