- 18 May 2010
- London
1.9% boost from 1.0.0.4 Agesa.
Thats over 10003 ABBA.
Be interested to see what those other 99 improvements are.
DO NOT USE THE X570 Taichi BETA 2.30 BIOS FOUND ON REDDIT.
If you do not want to spend the next 1 hour of your life trying to roll back to 2.11
Thanks for the feedback Panos, we are grateful for the warning. Is it corrupt, cant boot or just really badly unstable? Or is rolling back very hard? Did you try the one at https://shop.jzelectronic.de/news.php?id=1571896680&sw=AM4 If not no worries.
Tried the one from reddit as it was a safe zip file. The one you link is .exe and rather not use it.
The system boots very slow, after 2 self restarts. Setting XMP just hangs there trying to restore it for 1 hour. As every time it reboots and you think great, before it loaded windows was gone.
Then wasn't booting even after continuously reseting the bios. Had enough and rolled back to 2.11 on the first opportunity that let me load the bios.
When there is a proper bios, released directly by Asrock I will use it.
Thank god you were at least able to downgrade to 2.11. Sounds like an issue with the ram. Thank you for trying the bios and sharing the results.
You can always edit them yourself but I think there are more refined ways of doing this with Intel BIOSs than AMD ones right now. I updated my ancient X58 board with the last microcode updates with the security patches relatively easily.Would never touch a bios unless from manufacturers website.
Edit a bios file and flash it? Never heard of this. What is there to be gained?You can always edit them yourself but I think there are more refined ways of doing this with Intel BIOSs than AMD ones right now. I updated my ancient X58 board with the last microcode updates with the security patches relatively easily.
Updated microcode for abandoned boards, as I said. You can also fool Windows authentication but I doubt we want to discuss that here.Edit a bios file and flash it? Never heard of this. What is there to be gained?
