- 30 Dec 2003
- Bigger box!
I dunno weather to laugh or cry at the cost of that hardware and you pull out two cans of red stripe
The cpu fan goes to the cpu fan header and the case fan will go to the case fan header. This is why you read the manual. If you have more than one case fan then you got 2 choices. Disconnect one or get a fan controller kit that allows multiple fans attached.
That cpu paste should have been spread out with a card IMO not a blob personally. I just use a debit card (the non chip side) then wash it after works fine. Or something else with a nice edge.
A bit ‘studenty’ I know, but I genuinely like it!!
as for the fans, I have two ‘sys fan’ sets of pins. However, they’re both four pin, and my case fans are three pin...
told you all I have no idea what I’m doing!!
