But it was BRILLIANT, I thoroughly loved it, I'm glad I took the plunge as in my eyes I got my $60 from the evenings entertainment.Everytime you finish a game and get a cinematic video it's loading the next level so it does freeze and stutter till it's done. So no load timesReally enjoying this but the cinematic clips in the campaign seem to freeze every few seconds which is a bit annoying. Anyone having similar issues?
Took the plunge, just played the campaign from start to finish in one sitting... It's 0400 hereBut it was BRILLIANT, I thoroughly loved it, I'm glad I took the plunge as in my eyes I got my $60 from the evenings entertainment.
I just played a few matches, crossplay is weird and I hope the console guys disable crossplay for them selves as it's very unfair. But I also really like it, great fun.
I'm running on a EVGA 2080 ti XC Ultra, 8700k @4.8ghz and 32gb ram, with RTX on and everything cranked to max, I average around 110-144 (gsync on a 144hz monitor). Super smooth and the graphics are insanely good.
Nice what resolution?
Also a none spoiler question regarding the story.
#1 what difficulty did you play on
#2 I asked num 1 because I know each mission gives you a MP reward. Did you get one for each mission or might you perhaps need to play it in the hardest mode to unlock them all?
turns out I had another game open (rust)Sounds like your shaders aren't loading for mp
Cut scenes freezing and skipping here also. Gameplay just fine.
Btw. How do I set CTRL as crouch and prone with crouch being a press and probe being a hold? It looks like I should be able to do it in the menu, but I can't get it to work. Most other fps games allow you to do this. Xx
In the options, controls then movement, I did the same.
0610 here... First time I've done an 'all nighter' in years, gonna get some shuteye before it truly becomes an all nighter haha. I did NOT expect I'd be enjoying this game, oh how wrong I was!
